Old 01-06-2015, 10:36 PM   #1
Maggro
Motor question
Question, my dad took my motor apart since I'm still overseas and he can't just let it sit there. It's a 350 with four bolt mains. He sent the following message and pic.
Hello the crank and mains are in great shape and are cut to 10mm I inspected the cylinders and pistons and block is bored out to 60
I am not sure if can be saved, I will have it inspected and machined if is possible.
Any impute on this would be greatly appreciated.
Thanks folks
Maggro is offline   Reply With Quote
Old 01-06-2015, 10:43 PM   #2
truckster
truckster's Avatar
Re: Motor question
He probably means the crank and mains have been machined to .010 (ten thousandths), which is fine. As far as the block, .060 is as far as I would go over on the bore. If it's at .060 and the cylinder walls are in good shape, I would go with it (as long as there are no cracks in the block). If it's at .060 and the cylinders need to be bored, I'd say it's time for a new block.
truckster is offline   Reply With Quote
Old 01-06-2015, 10:44 PM   #3
70'
70''s Avatar
Re: Motor question
Guess I missed the question?
70' is offline   Reply With Quote
Old 01-06-2015, 10:50 PM   #4
tcrist
Re: Motor question
I have seen them go over +.060 but you "can" start having heating issues due to the thinner cylinder walls.
If it is not scratched up real bad, you can just hone it to rough up the cylinder walls.
Terry
Soon to be retired and moving to Bristol, TN.
tcrist is offline   Reply With Quote
Old 01-06-2015, 11:08 PM   #5
Maggro
Re: Motor question
70' your right, I forgot to ask the question which was is. In the opinion of the more experienced builders here can this block be reliable to build on. He says it appears to be in great shape no scratches in the cylinders and no cracks.
Old 01-06-2015, 11:30 PM   #6
70'
70''s Avatar
Re: Motor question
The only way to know on the cracks for absolute certain is mag particle testing. Most folks call it magnaflux. As far as further machining, I would not personally go beyond the .60 that it's already at, as pointed out it can cause overheating issues.
Old 01-06-2015, 11:35 PM   #7
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: Motor question
Good advise given, bottom line is...Take it to a machine shop and have it spec'd...
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 01-07-2015, 02:45 AM   #8
mechanicalman
Re: Motor question
Thanks folks
All sound advice. I would like to add that you can have the block sonic tested for thickness before you decide if it's worthy. My machine shop in Glendale AZ offered to send mine out to a shop that does it but I declined as I only went .020 on that engine. You can read this article about sonic testing if you are interested.
http://www.hotrod.com/how-to/engine/...lvaged-blocks/
Some engines can go .060 and are just fine while others cannot, sometimes this is due to "core shift" of the engine casting. If interested you can read about it here.
https://books.google.com/books?id=GU...0shift&f=false
mechanicalman is offline   Reply With Quote
Old 01-07-2015, 07:16 AM   #9
hamjet
hamjet's Avatar
Re: Motor question
X2
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
