Old 01-07-2015, 12:51 AM   #1
slotard
Cost for 4.8/4L60E/ECU/harness? What else do I need?
I found a 4.8/4L60E with accessories, ECU, harness.
The guy posted it for $800obo, it's less than an hour each way. Around here, that seems to be a pretty good deal.
What else would I need? Any specialized tools? I know I'd need engine mounts, I imagine tranny mount, likely a new driveshaft. How much wiring stuff?
Thanks for any advice.
1973 C20, 350/350
slotard is offline   Reply With Quote
Old 01-07-2015, 03:45 AM   #2
l92powered77
Re: Cost for 4.8/4L60E/ECU/harness? What else do I need?
you can get the motor mounts as well as accesory brackets from www.dirtydingo.com and as far as wiring and gas pedel and mass air flow sensor and harness and fuel system and ecm programming check out www.psiconversion.com talk to John or Jeremy they will help you out. you will need headers also.. driveshaft ...good luck !!
l92powered77 is offline   Reply With Quote
Old 01-07-2015, 09:28 AM   #3
slotard
What years require a new pedal? He has all of the accessories for it.
1973 C20, 350/350
Old 01-07-2015, 10:09 AM   #4
Matt Cramer
A drive by wire throttle body would require a new pedal; a cable operated one would not. You can fit the cable operated throttle to a drive by wire engine; that's what I did.
Matt Cramer
1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD
4.8 LS build thread
Matt Cramer is offline   Reply With Quote
Old 01-07-2015, 10:39 AM   #5
mattcrp1
mattcrp1's Avatar
That's a good deal, I paid $1000 for mine and had to drive to Sac. If you can get the drive shaft yoke that would be helpful. I had to get trailblazer ss exhaust manifolds for my swap, but i found a pair used for a decent price. Good luck.
My Chevy habit is paid for by Ford diesels...
Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355
Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748
Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974
IG mattcrp1
mattcrp1 is offline   Reply With Quote
Old 01-07-2015, 10:55 AM   #6
slotard
The guy is in Dixon, so not horribly far (although farther than I've taken the truck on the freeway... 4.10s, 30.5" tires, and TH350 mean it screams even at 55-60). I'll probably head up there this weekend. He claims he pulled it himself to do a swap on something he has and never got around to it, so I'm hoping he pulled everything.
Is there anything wrong with using his accessories (alt, ps)? How about AC, what would it take to make the new compressor work with my factory condensor/evaperator?
1973 C20, 350/350
Old 01-07-2015, 10:59 AM   #7
mattcrp1
mattcrp1's Avatar
I am using all the accessories on my donor engine. I had to pull the old valve on the p/s pump and install it on the new p/s pump to adapt the p/s line pressure line. The a/c would not fit on my 76 and I had to remove it.
IG mattcrp1
Old 01-07-2015, 11:54 AM   #8
slotard
Are there any 4.8/5.3 engines that I should stay away from? If so, how do I tell? I'd rather not get a bad engine (he claims it's good but you know how it goes).
1973 C20, 350/350
Old 01-07-2015, 12:51 PM   #9
slotard
How much work is swapping the valve? What happens if you don't?
1973 C20, 350/350
Old 01-07-2015, 03:09 PM   #10
Wasted Income
Boosted Member
Wasted Income's Avatar
5-10 years ago that would have been a pretty steep price, but now....that's actually pretty decent.
I've had good luck with all of my junkyard engines. They are pretty durable. Change the oil, clean it up, and let er rip.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 01-08-2015, 09:48 AM   #11
Matt Cramer
There were a few iron headed engines; if you run into one of those, I'd hold out for an aluminum headed one. These only seem to have been made from 1999-2000, IIRC.
Matt Cramer
4.8 LS build thread
Old 01-08-2015, 10:55 AM   #12
Wasted Income
Boosted Member
And they were ONLY 6.0L engines. No other LS engine other than the very early LQ4 came with iron heads.
Turbo diesel
Old 01-08-2015, 11:00 AM   #13
mattcrp1
mattcrp1's Avatar
The valve for the p/s is an easy swap, its needed so you can use the factory p/s line on the 76 c10 and simply threaded it into the donor pump with the original valve. Its not totally necessary, if you want to go get a custom p/s line made with fitting and adapters, that works as well. I am "frugal", so this was less expensive.
IG mattcrp1
Old 01-09-2015, 09:26 AM   #14
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
hOME DEPOT LETS YOU RENT A TRUCK FOR LIKE $20\DAY i BELIEVE
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 01-09-2015, 11:07 AM   #15
slotard
I'm pretty sure it's $20 for 75 minutes, not all day. What does that have to do with this? I'm not gonna steal the engine out of one, or let the truck get "stolen" etc
1973 C20, 350/350
Old 01-09-2015, 02:54 PM   #16
ls1nova71
ls1nova71's Avatar
Pretty sure this is what Clyde was referring to, I don't think he was implying you rent a truck and take the engine! Would make it pretty hard to return I would think.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 01-09-2015, 02:59 PM   #17
mikewoods
mikewoods's Avatar
Haha, yeah I think he's saying rent the truck to pick up the engine...
Uhaul has a $19.99 pickup truck for the day.
"The Mustang’s front end is problematic, get yourself a Firebird. "- Red Forman
mikewoods is offline   Reply With Quote
Old 01-09-2015, 03:20 PM   #18
slotard
Uhaul charges mileage that makes it pretty damn expensive.
I can deal with the 60-65 miles each way, it'll just be slower than if I was in something modern.
1973 C20, 350/350
