Old 08-21-2003, 12:43 PM   #1
moneyguru
moneyguru's Avatar
Heartbeat of a Chevy....will it work?
OK, this isn't really 67-72 related, BUT it is Chevy related and you guys seem to really know your stuff.
Interesting recipe
#1 I have a 90 Suburban that's body is slowly rotting away
#2 I have alwasy wanted a Jeep Scrambler
#3 aftermarket replacement jeep frames and bodies are available
Jeep scramblers are getting popular and they were not many made. Having always wanted a SB chevy powered one I am pondering building one from the frame up using an aftermarket frame, fiberglass body and the drive train from my 90 suburban.
There are alot of adapter kits for installing sb chevy engines in these trucks so I don't see that being a problem. One of my concerns is the axle width of the Suburban vs Scrambler.
I can't find these measurements and was hoping somone here might know if this would work.
Also I was wondering if anybody knew how this would be titled afterwards?
Any ideas, thoughts?
M.G.
moneyguru is offline   Reply With Quote
Old 08-21-2003, 01:59 PM   #2
jays68yak
jays68yak's Avatar
try pirate4x4.com, they might flame you but you might also get a lot of advice.
1969 Chevy Project SWB Fleet, 20s, 5.3, t56, in the weeds.
1970 Chevy Truck cab on a 1979 Jimmy frame-8.1 liter 496 bbc/sm465/np203-jeds doubler-np205/d60/14bff Welded/42 tsls on recentered H1s
1998 Chevy Crew Cab K3500 SAS'd with hpd60, links and swayaway coilovers. 8.1l vortec DD/towrig
"I like long walks, especially when they are taken by people who annoy me. "
jays68yak is offline   Reply With Quote
Old 08-21-2003, 02:12 PM   #3
VTKidder
Advance Adapters (- clicky -) has the same kind of stuff....they may be able to provide insight for you as well.
VTKidder is offline   Reply With Quote
Old 08-21-2003, 02:22 PM   #4
RON WOODGEARD
Resident Young Old Dude !
As far as the rear end goes, just do a measurement, What you are wanting to do, the rear end is a drop in the bucket in comparison....
As far as the title goes, Be sure you have All of the receipts, and original title,(to the frame) And in your case you will have the invoice/paperwork on the glass body shell.They combine that on paper and classify it as a homebuilt vehicle. The last one of these I did was in Washington State, 20 some years ago, I put a Corvair Body on a 64 Chevy "X" frame, With a 454-4Spd. They classified it a 64 corvair, home made. But the State Patrol Inspection station had it for so long doing their check for stolen components, I thought they owned it and I was visiting it..
We use to do the Corvair thing, and, Take a 4 door 55 to 57 chevy station wagon and cut out the back doors shortening the body, The 64 chevy frame comes together in an "X" configuration, easy to shorten to match the body, Some we didn't bother doing the title with,
Check with your State inspection station to get all of the particulars..
Good Luck!!!
Ron
RON WOODGEARD is offline   Reply With Quote
