Biggest Battery Fitment?
I need more juice. What with the higher compression and then cold weather...the group 34C I have can only do so much. I will probably be relocating the battery to the driver side front because of interference issues on the passenger side. Has anyone fit a bigger battery in the stock tray or found a bigger tray that will fit well like the stock one does up on the core support?
Moderator
![]() Join Date: Dec 2012
Re: Biggest Battery Fitment?
Consider a group 78. Not as tall, but you can get some with some serious output. Well over 1000CCA. Used in 90s Caprice/Roadmaster/etc. They can be found with dual (top/side) terminals. No problem turning over a 10.5-1 compression V8 in -40C weather.
Thank you very much. And the group 78 fits where the stock battery fits?
Moderator
Should be fine, but check the dimensions online. A stock 78 is side terminal, though!
![]() Join Date: May 2007
there is a lot of room to go up before you hit the hood, I had to raise mine pretty far and it still fit. they sell post kits for side terminal batteries also.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
