![]() Join Date: Jun 2010
Sprung a little leak today.
I noticed today when I got home that the carpet on the trans tunnel was wet. I felt it and it didn't smell like antifreeze or anything. I am not sure what it is from. Everything was working fine.
Roy 85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818 1987 R10 shortie |
Re: Sprung a little leak today.
I have a 98 that leaked through the heater. Mine filled up the blower case and when I turned the fan on it would come out but farther to the right than your leak. I removed the blower motor and could reach up to the cowl and feel the seal to the cowl had deteriorated. My cure was to block the air inlet on the pass. side and make any water that did come in the cowl run to the drivers side. No leaks for about a year now
| Bookmarks |
