Old 01-07-2015, 06:45 PM   #1
CrewCab59
CrewCab59's Avatar
Quadrajet 7042210 problem
Need some help with a quadrajet 4mv 7042210, just had the carb rebuilt idles great @ 700 rpm ,when you raise rpm up to 1400 or higher it wants to start running rough and will die but if you keep moving the accelerator pump the rpm will rise with no problem.
When engine starts to stumble you can close the choke a 1/8" and will clear up ,
I have check divorce choke adjustment , rod is at the level with the arm slot.
Engine has 18in of vacuum , will drop to 13" when you reach 1400rpm
Engine specs
New gm crate 350
Stock manifold
Stock exhaust manifolds
Points distributor
New plugs,wires, cap,rotor,fuel pump.
Any help would be great .
Scott
1972 Custom Deluxe 20 4x4 burb
1971 GMC SWB CST 4x4
1972 GMC k20 4x4 (X- brush truck )
1971 Chevy CST Blazer 4x4
1971 Chevy C/10
1970 Cab Chassis C30 157"
1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica )
1988 Chevy V30 4x4 wrecker challenger 4812
CrewCab59 is offline   Reply With Quote
