Old 01-07-2015, 09:18 PM   #1
Southcity
Southcity's Avatar
Radio Delete for the DIY's
My version of a homemade radio delete plate, can be used for years 60-66 or 67-72. Hardware was purchased at local OSH, total cost came to under $20.00.
What you need:
1. A dash that has sadly been cutup at one point in it's life
2. One radio faceplate, I got mine here at Retro Sound - $15.99
http://www.retrosound.com/product-p/faceplates.htm
3. Two 3/8 hex head course thread bolts, approximately 1 1/2 inch in length - $2.39
4. A few washers for the two bolts - $1.50
5. Two chrome push button nuts - $2.39
Dash was cut at some point in it's life
Radio faceplate from Retro Sound, comes with the two backing plates
I got mine with the black textured surface and chrome trim to match the after market air-con vents
Hex head bolts - number of washers needed depends on fitment
3/8 Chrome pushon button style nuts
66 GMC Suburban Custom
66 Chevy K10 Suburban
Southcity is offline   Reply With Quote
Old 01-07-2015, 09:29 PM   #2
Southcity
Southcity's Avatar
Re: Radio Delete for the DIY's
Installation is a lil too easy:
Pre-assemble one side of the faceplate by adding some washers to bolt, push bolt through backing plate with threaded end to front of faceplate and test fit to determine how many washers are needed for a good fit. I ended up using four washers
Start by placing one of the backing plates with bolt and washers in stereo opening and steady it with a finger
add faceplate and then loosely attach one of the pushon button style chrome nuts, repeat same steps for other side
hand tighten and adjust - done!
Old 01-07-2015, 09:31 PM   #3
Southcity
Southcity's Avatar
Few more shots.
For more money and a really custom look you could use the knobs from two of the lighter assemblies (Black & Polished - http://www.ecklerstrucks.com/chevy-t...1960-1963.html) which match the other controls on the dash and the knobs have a threaded shaft, come apart and can easily be used to attach the faceplate instead of the cheaper alternative of using the bolt+pushon style button nuts.
Old 01-08-2015, 02:16 AM   #4
doobiebro
doobiebro's Avatar
Kool idea! Thanks for posting..
CURRENT & PAST CHEVY TRUCKS
60 C-10 Apache short step side
62 C-10 short step side
66 GMC Long bed fleet side 305 V-6
77 C-20 Custom Deluxe (Blue Goose)
doobiebro is offline   Reply With Quote
Old 01-08-2015, 04:34 AM   #5
Slow Build
Slow Build's Avatar
Pretty cool. If you mount some type of pouch behind it you could also use it to store sun glasses, cell phone, drumsticks,........
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 01-08-2015, 06:36 AM   #6
Mjminino
Pretty sweet!
Mjminino is offline   Reply With Quote
Old 01-08-2015, 08:50 AM   #7
Grizz1963
Grizz1963's Avatar
Nice detailed description and write up.
Thanks for sharing.
My dash was eaten by an angry Badger at some point and I just bought a repair piece but have to say this is easy, simple and highly effective.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 01-08-2015, 11:42 AM   #8
Lokin4AReason
Lokin4AReason's Avatar
neat idea ... thanks for the share =0)
dont want to hear excuses, i want to hear solution(s)
Lokin4AReason is offline   Reply With Quote
Old 01-08-2015, 03:31 PM   #9
Southcity
Southcity's Avatar
Yep the options on what you can mount behind the faceplate are many but of course Slow Build suggests drumsticks and that's what I'll be using it for, cell phone holder too. Good to hear from you Slow Build - Happy New Year!
Old 01-08-2015, 07:45 PM   #10
66LSx
66LSx's Avatar
I cheated... mine too was eatin by a die grinding badger by the P.O....
1966 C10 SWB Fleet
5.3L LM7 Vortec / 4L60e Swap
1966 C10 w/ 5.3L/4L60e Build Thread
2012 GMC Sierra 5.3L 4x4 CCSB
66LSx is offline   Reply With Quote
Old 01-08-2015, 09:18 PM   #11
Mjminino
I like that idea, but I LOVE my music while cruising.... YES I like the sound of the motor too.
Old 01-08-2015, 09:19 PM   #12
Mjminino
What gauges are those 66lsx? I really like those.
Old 01-08-2015, 09:38 PM   #13
66LSx
66LSx's Avatar
Speedhuts.... there amazing.
Really wish I had an OEM appearing radio delete tho....
1966 C10 SWB Fleet
Old 01-08-2015, 09:43 PM   #14
Mjminino
I pm'ed you
Old 01-26-2015, 07:43 PM   #15
Southcity
Southcity's Avatar
Updated photo using lighter assembly knobs purchased here:
The lighter assembly knob unscrews and has a threaded stud just long enough to run a nut and washer to secure the radio faceplate and of course nicely matches the existing knobs on the dash.
Old 01-26-2015, 07:55 PM   #16
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
I also had a hacked dash. This was my solution.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 01-26-2015, 09:45 PM   #17
hotrod66
hotrod66's Avatar
I also had a hacked dash but I finally fixed mine since mine was down this far. nice idea would have done this if the truck was nicer to begin with. I will remember this cool trick.
[ATTACH]1355181[/ATTACH]
Between saying and doing many a pair of shoes are worn out
hotrod66 is offline   Reply With Quote
Old 01-28-2015, 11:58 AM   #18
C-10cutty
C-10cutty's Avatar
Good idea.
C-10cutty is offline   Reply With Quote
