Assembly manual
Is there somewhere a person can get an online version of the build manual for 67-72's I need to look at a couple things that have slipped my mind.
I am installing a polished tilt column from CPP and I can't remember what held the damn thing in at the dash. I also wanted to see what all the holes in the firewall had coming out of them. Any help would be greatly appreciated! |
Re: Assembly manual
The column is held up by a semi- u shaped strap about 1/2 inches wide. It has a bolt hole on each side. If you do a search, someone was nice enough to scan in each manual for the corresponding years. A search will also net you a pic of a firewall with each hole labeled for its intended purpose. Best of luck!
http://67-72chevytrucks.com/vboard/s...d.php?t=583390 here's one |
Re: Assembly manual
The Older Generation
Re: Assembly manual
Here are the brackets for the steering column. Small angled one goes in first, then the big plate, then the trim piece. Also a picture of the firewall holes. The "windshield wipers" should be windshield washer hoses and the "wiring" would be to the tail & brake lights. I cant remember who originally posted it. There may be some different holes on different years. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 01-08-2015 at 12:50 AM. |
Re: Assembly manual
That's awesome, thanks!
Re: Assembly manual
I found the one on the left and the lower one in that picture but can't see the top one, does it matter that this was a manual trans 68 with hand brake? It looks like maybe the hand brake bolts under there.
