01-08-2015, 04:38 AM | #1 |
Mixing An 03 With A 68
Just Purchased An 03 Yukon With A 5.3 And A 4L60 In It. I Want To Put Them In My 68 C/10. It Currently Has A 355/350 In It With A/C, P/S, P/B.....Any Suggestions On What To And What Not To Do?? What's The Easiest And Best Ways Of Making It Go Together??? Any Suggestions And Helpful Comments Are Welcomed........
I've Reached The Age Where Happy Hour Is A Nap!! |
01-08-2015, 06:46 AM | #2 |
Re: Mixing An 03 With A 68
I'm interested in seeing this come together. I'm planing on doin the same thing to my 69 shortstep. There is one site I found that has a lot of wiring info, LT1swap.com
This guy breaks down the whole harness from whats hot and whats not. Some of the info is a bit overwhelming though. Good luck, and hope all goes well. |
01-08-2015, 11:04 AM | #3 |
There's tons of info on the LSx Swaps section of this board:
67-72chevytrucks.com/vboard/forumdisplay.php?f=206 All the FAQs are covered. Once you're up to speed on the basics, if you have any super-specific questions, ask over there and you'll probably get a knowledgeable answer. What you're doing is a super-common swap, so shouldn't be too many surprises as long as you do your research. Looks like it will be cool when done. Have fun!
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER 1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD 1976 Trans Am | 400/4-spd | SOLD 1976 Trans Am | 455/4-spd | TOTALED |
01-08-2015, 12:52 PM | #4 |
The Older Generation
I will have it moved to the LSx Swaps Forum. LockDoc
01-08-2015, 05:32 PM | #5 | |
01-08-2015, 10:55 PM | #6 |
I Guess I Need To Start From The Bottom And Move Up.... I Have Seen A Couple Of Different Motor Mount Set Ups. One Was Basically A Flat Plate With Holes That Accept The Original Motor Mounts, And The Other Needed The Frame Mounts To Be Changed To A Later Model. Other Than "Kits" I Haven't Seen Much About Trans Mounting. Do The Original Trans Mounts Work?? Is The Engine Angle Alright Using The Factory Trans Mount, Or Is An Aftermarket Mount Needed??
01-12-2015, 01:25 AM | #7 | |
I am planning on using an original transmission cross member. I'm just not sure which one yet. I have one for a TH350 and one for a TH400. Whether or not you can use any of the original frame holes depends on where your engine is located front to back, from what I read on here. I don't know about the angle yet. LockDoc
01-14-2015, 01:15 PM | #8 |
following this. i am in the pre planing stage.. with my 68
01-17-2015, 09:56 PM | #9 |
It's Slowly Coming Apart...
I've Reached The Age Where Happy Hour Is A Nap!! Last edited by ETsC10; 01-18-2015 at 02:57 AM. Reason: removing hint of FS |
01-18-2015, 12:11 AM | #10 |
Sort of like taking all the good from the old truck and inserting all the bad from the new...
Why not just buy a volt? |
01-18-2015, 01:32 AM | #11 | |
Pretty sure this is considered trolling.....
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
01-18-2015, 01:34 AM | #12 |
Nothing wrong with creativity
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
01-18-2015, 05:41 PM | #13 |
If Taking A Well Worn 355/350 That Was Built In The Mid 80's Is Taking The Good Out, Then Yes.....
01-19-2015, 09:27 AM | #14 |
Hand Crafted C-10
Cool upgrade 68SSC10 ... subscribed!
. Forum Guidelines and Rules
Buying and Selling Code of Conduct Become a Board Supporter! Truck FAQ Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member... |
