Speedo
I was wondering why there is a little hole in my '52 trucks speedo between 40 and 50 mile ... Behind this little hole sits a bulb, but this bulb does not work ... Probably a stupid question ... Anyone?
![]() Join Date: Aug 2014
Re: Speedo
Not sure as I don't have a AD but could it be the headlight high beam indicator light?
Re: Speedo
Could be. The light behind the hole is not connected, so I wouldn't know.
Re: Speedo
My high beam indicator is the small hole on the bottom of the gauge. I don't have a light between 40-50.
Re: Speedo
I should have also said this is for a '49. Not sure if they changed anything between the years.
![]() Join Date: Aug 2011
Re: Speedo
It is definitely the hi beam and should have a red piece of plastic behind the hole so it shows red.
Pat 1949 unmolested Indy Farm Deluxe AD 1949 Standard 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=581544 |
Re: Speedo
Are you planning a refurb or just cleaning them up? I did a refurb but haven't installed yet.
Hollister Road Co.
Re: Speedo
50- 53 have the indicator light at the top, 47-49 up have it at the bottom the gauges also have different mounting tab locations on the clusters and dash
Re: Speedo
Good to know dwcsr
