Did Transmission oil coolers come stock on 72 Blazers?
I'm not sure if this was added by the PO or if this came as an option.
My Build Thread 72 K5 http://67-72chevytrucks.com/vboard/s...d.php?t=628612 Build version 2.0: 72 K5 6.0 LQ9, 4L80e, NP205 http://67-72chevytrucks.com/vboard/s...d.php?t=793192 ____________________________________________ 1972 CST K5 Blazer Dark Olive |
Re: Did Transmission oil coolers come stock on 72 Blazers?
Not stock.
Thanks.. I have a brand new engine, rebuilt trans and T-case.. It's not going to be a daily driver sitting in traffic. I'd rather not have it in there because 1. It looks out of place 2. the bracket holding it together looks hideous
I can get away with not using, right?
A transmission cooler is never a bad thing to have - heat kills auto transmissions. But if you don't like it remove it.
![]() Join Date: Mar 2004
Agreed - but I wouldn't even think about removing it.
-Keegan- '72 Jimmy 4x4 - 5.3/4L65E/NP205 swap http://67-72chevytrucks.com/vboard/s...d.php?t=663780 |
My old 72 sub an 72 blazer had the kind that had a cooler in the radiator end core, That's what came from the factory.
I wonder if there is way to know if its factory.. If it factory I would have it rebuilt but if it was an aftermarket I would opt to getting a brand new one.
Carpe manana
![]() ![]() Join Date: Dec 2010
Aftermarket or dealer accessory - if a factory option would be listed on the SPID and I've not yet seen a factory RPO for a tranny cooler or a SPID listing such. Can't hurt to have though!
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
That aftermarket air to liquid series cooler is not very efficient.
It should always be plumbed after the factory (liquid to liquid) cooler in the radiator as a supplemental cooler.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
![]() Join Date: May 2007
Shoot a little flat black on it, and it will be nearly invisible.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
