Old 01-09-2015, 01:57 AM   #1
cfan10
cfan10's Avatar
Cool what to look out for?
What are problem areas on a 1990 Chevy suburban body seems good...supposed to see one Saturday but owner seems kind of vague on info...I know the frame by the gearbox is a concern. Says I need to see it myself, but that suspension is not great...whatever that means. Leaking areas I need to look for. Just anything besides the normal stuff tires/batt/alt/starter/tune up/brakes/oil change or fluid flush.
1990 Chevy suburban 350 unsure of trans. Miles unknown.
As always thanks for all advice/experience.
Rest In Peace:Mikhail {Mickey Rooney} Alpha 2/5/13 Omega 7/22/14 10:28AM I love you tremendously and outragiously Superpuppi Thai Ridgeback...The most intelligent dog known to me.
Don't mess with my truck, my momma or my money...not necessarily in that order. ©
Stand for something or fall for anything.
[LIST][*]'98 Bourbon St. Brawl ©2010
cfan10 is offline   Reply With Quote
Old 01-09-2015, 01:59 AM   #2
cfan10
cfan10's Avatar
Re: what to look out for?
Its supposed to turn right over first time. Are these 350 TBI any good no experience with TBI whatsoever. Thanks.
Old 01-09-2015, 02:48 AM   #3
andrewmp6
Being a 90 the trans should be a 700r4 or trubo 400 if its 3/4 ton or bigger.As far as the frame cracking around the steering box its more common on 4x4s but can happen on 2wd also.Check for rust everywhere from the body to the frame.If it has a roll down back window make sure that works.
andrewmp6 is offline   Reply With Quote
Old 01-09-2015, 05:33 AM   #4
cfan10
cfan10's Avatar
^Thanks...its a few hundred bucks so not expecting much as far as body goes, as for gearbox cracking frame my truck is an 84 swb 1/2 ton and I had the frame welded. But after dealing that, it scares the h%ll out of me to half to go through it again. I will inspect it very well. He wants $850 but will try to get him to $7-750 tops if it has serious issues.
How can I convert a 350 TBI over to carb?
Old 01-09-2015, 06:37 AM   #5
andrewmp6
I would leave it tbi unless someones messed with it and it don't run right.
Old 01-10-2015, 02:02 AM   #6
cfan10
cfan10's Avatar
Thanks for the input.
