designed drop trailing arms
So I don't have a truck anymore : ( but I still love these trucks. ive designed these trailing arms to drop a truck two inches with out using blocks.
they will be made out of 1/4 steel and have ballistic poly bushings for the front. I've also designed a new front bracket for the trailing arms to mount to. I also added a few degrees to help correct the pinion angle just finished drawing today, let me know what you think. also a pic of my old truck and my dads pro street 64 |
Re: designed drop trailing arms
front brackets cut out. but I might have to make a few changes
this might be better if it was moved to the suspension forum
That's pretty cool. I really like the rear trailing arm design. Great job! What are you cutting with? CNC Plasma table? I noticed the lead in in the holes. I use a .050" radius lead in on holes on our water jet. Are you willing to share your designs?
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
The bracket was cut out on a plasma table and its brand new. I was his first customer so he is still fine tuning it. I think im going to have the trailing arms cut out on the laser. as far sharing the plans im going to keep them to myself due to I might try and produce these to sell if they works out.
![]() Join Date: Jan 2011
Suggestion on your front bracket. Ad more material around the bolt hole or ad a doubler. You may see some elongation in the hole over time with that little of material. Set it up with an undersized hole so after bending it can be reamed to size to allow a tight straight bolt fit.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
there is actually more material around that hole then a stock bracket. but it is one of the changes I'm thinking about
I don't know what ballistic poly bushings are, and it looks like a heim joint in the picture. Learning op for me thanks in advance if you choose to expand on this.
I'd be interested. I'm in the Boise, ID area. Subbed for more info and upcoming pictures. Do you have a 67-72 c10 you can try them on once made?
Hope this isn't rude to ask, just thinking it'd be neat to see what it looked like, and I have no clue how or where the brackets bolt on. Soooo can you draw up pics of the trailing arms and brackets installed?
Going through life's daily grind, I can feel the effects of this physical body's fleeting days, But with a young spirit I look toward a brighter day, knowing that in the eyes of eternity, I am but a babe in the arms of my Lord......... |
The Older Generation
Just remember, you have to be a "Premium" member in order to sell them on the board. Also, if this turns into a "for sale" or "I want to buy" thread it will be locked and won't do anyone any good. Just a heads up..... LockDoc
#13 | |
#14 |
lock doc. no problem
at this time they are just a drawing on my computer and im trying to build something cool : ) and if they do turn out how Im hoping then at that time will look into trying to reproduce them to sell. just so I know, what does it take to become a premium member |
#15 | |
I have a frame in my garage and that's it : ) |
#16 |
so I finally ordered the first set to get cut out on the laser today! I Should see my parts on the 20th.
Ive made a few changes to the first design. pretty excited to get started on these. hoping they turn out as cool as I pictured. when I get the parts I will post some photos. |
#17 | ||
That sounds great. Glad you are finally getting the project off the ground. Keep us posted.... I have thought about building a pair of them for my future '67 1 ton Dually project, as I plan on putting coils under it. LockDoc
#18 |
Drop trailing arms are one step closer! Got the parts off the laser today and had to quick mock one of them up!
#19 |
One more
#20 |
That looks awesome!! Good job.
#21 |
Sweet!
#22 |
I got the front mounts drilled and tapped today. The Ballistic joints should be here tomorrow. On Saturday I have to fly to Hawaii for work but I should be back home on Monday night. The plan Is to start welding these trailing arms up next week.
#23 |
Got the ballistic joints yesterday. There huge!
#24 |
One more with a tv remote to show the size
#25 |
![]() Join Date: Apr 2007
Looking good!
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=456220 Best 1/4 mile time 12.1 @ 111 w/traction issues 1969 GMC SWB 1964 chevy II Nova ht |
