Ground clearance ?
As some of you know I have been entertaining the idea of putting a 95 C4 Vette front suspension on the 67, but after getting more info from some guys on here about what would need to be done I may be re-thinking that.
I really dont have the cash for the fancy front ends that cost thousands of dollars so I may start piecing something more reasonable together such as drop spindles and springs and maybe some tubular A arms. With stock A arms what would the ground clearance be with 2.5" drop spindles and 2" lowering springs? I have nothing to go off of since the PO took the torch to the original springs to half ass lower it. Would the lowest point be from the lower A arm or from the cross member? If its at the A arm, would that be increased with tubular A arms? I have no idea what the ride will be like with this drop method as like I said the springs were torched and it rides like crap now and I dont think anything was done with the shocks. Im pretty sure they bottom out now. Do the lowering springs stiffen the ride from what stock was? Not that I know what it rode like stock.... If I do the 2.5' spindles and 2" springs in front with 5" springs in back will that give me a stagger in front to back height? Im looking to be like 2" higher in back. Much appreciated.
"Hey... its only time and money right? Just do it." 67 Short Bed under major construction http://67-72chevytrucks.com/vboard/s...=651356&page=8 |
