55-59 - Want to do interstate speeds
I've got a '57 1/2 ton longbed.
I put the outside-the-frame power steering box on it, tapered roller bearings, 12" front disc brakes, new shocks, new kingpins, replaced the worn out bushings - and it's still like steering a boat at 60 mph. Will a front / rear sway bar kit make interstate speeds more manageable, or am I at the limits of what I can do on the original leaf springs & beam axle suspension? If the $250 for sway bars is going to make 70 mph a safe and reasonable speed, then I'm all for it. I'm not interested in spending $750 on new leaf springs, a drop axle or anything else but a 1/2 ton IFS with big brakes. Just wondering what I can expect from a sway bar kit - because if it won't get me "there", I'll save my money for a Crown Vic or Dakota or C10 setup.
"Over my head" 1957 Chevy 3200, big rear window & 6 lug. Front disc, power steering, Vortec 4.8 / 4L60E swap, hydro boost brakes & patina. |
Re: 55-59 - Want to do interstate speeds
65Gregg Blue long bed White TBSS 61 Impala “The two most important days in your life are the day you are born and the day you find out why.” Mark Twain |
Sway bar likely won't help.
You might have created a little bump steer with the power steering set up. Have you looked into a steering dampner. Like this. http://www.autopartsway.ca/part.cfm?...fumufgodvjca-g |
A steering dampener might very well help.
Why don't you think a sway bar would do much for me? Also - I'm not sure on bump steer. I read that these trucks had some bump steer in OEM configuration? Never got to drive it stock, so dunno. The drag link is about the same length as OEM but positioned further forward.
![]() Join Date: Jan 2011
What are your alignment specs? If it has close to no caster in it or not much toe that will make it wander some.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
Hey fellas, I'm new here but been tooling and driving my '59 for years with a power Toyota box from CPP and I'm tired of bump steer.
I can drive it 100MPH but get it on some washboard or uneven track and it picks it's own line... not always the one I want either. Was gonna put a damper on when I found the No Limit power rack for solid axle. ![]() Anyone running it, any good, known issues?
Déjà vu. It's that feeling you get when you hit your thumb with the hammer a second time '59 Chevy 3100 Stepside |
This! Read the Make it handle thread and there is some good information regarding steering/handling/suspension.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
#8 | |
I found this one
There is not one specific to certain years. A lot of the information in there is good regardless. I know the suspensions are very different but the theory is the same.
#10 | |
FWIW, I have front and rear sway bars on my truck and SensaTrack shocks - truck is lifted a few inches - but I'd love to upgrade shocks. Settling in for another 51 page thread read ![]()
Looks like the "magic formula" is 5-6° Caster, -0.5° to -1° Camber and about 1/8" inward toe. I have all but the caster, I'm only at 2° at the moment.
I can increase the caster easily enough, but I'm sure that won't cure bump steer completely... any thoughts about adding a steering damper like 4x4 guys do?
I've been looking in to that a bit. Classicparts.com has a kit, it's $80. I am fairly certain it's just a reboxed Rancho #7100 kit, which sells for 50-something on Amazon.
Looks like if I move one lower shock mount to the front of the axle (both are in back at the moment) and fab up a mount that attaches at the U-bolts, it would be trivial to put the other end of the shock on the tie rod. This would help keep the truck from wandering. Talking to the foreman at the auto shop, he seems to think that flipping the shackles from the front of the leaf spring to the rear would smooth out the ride - it works for the Jeep guys, anyway. It's a lot of rivets & drilling but it could be done. You could even swap to coilovers & a leading 4-link + panhard setup with the beam axle, though that might be getting too much work.
#13 | |
BTW, I can't find a Rancho #7100 anywhere but I do find a ![]() Both my lower shock mounts face forward. I had them professionally modified to keep the steering knuckle from hitting the shocks when I was running Rancho shocks - but those shocks were too stiff. I am now running Monroe shocks until I finish tuning the stance and upgrade to a better shock like Billsteen. I'm not sure I'm keen on reversing the springs, but I'd like to see and hear from guys that have done this.
Déjà vu. It's that feeling you get when you hit your thumb with the hammer a second time '59 Chevy 3100 Stepside Last edited by octanejunkie; 01-14-2015 at 12:52 PM. Reason: link to stabilizer kit added |
#14 |
55-59 Steering Damper, frame-mount option
Found this while trolling on Amazon looking for steering dampers;
![]() I've seen a setup like this on many 4x4s
#15 |
I haven't figured out a great solution for frame / axle side mounts yet. That kit doesn't present any obvious solutions - if you come up with a good one, be sure to let me know.
#16 | |
![]() I will attempt the damper install this weekend and probably launch a new thread if it all works out. If not, I'll updated here. BTW, found this ![]()
#17 |
Installed a steering damper this weekend. Thread on it here.
#18 |
Nice followup! Just read your link.
I think I'm going to add 4-6* caster & a stabilizer, just want to collect a couple paychecks first.
#19 |
Just remember to search for 2" wide pinion shims, many on the market are 2.5" wide. Mine are by Pro Comp.
