Old 01-10-2015, 07:06 PM   #1
rs74
rs74's Avatar
Got a lowering question.
If I want to just lower a truck lets say 2/4 then what are my options. I lowered my short bed 4/6 with 2.5" drop spindles and 1.5" drop springs and a flip kit in the rear. If I get another C10 for a daily driver I may want to drop it just a little but not as much as my short bed.
So would it be better to do drop spindles and stock springs or do springs and keep the stock spindles. I'm not cutting any springs. Just not my thing. The thing that I am really not sure about is the rear. I don't think I would really want to take any leaf springs out. Does that leave me with putting a drop shackle on my only other option? I would just want a couple of inches of drop to level out the truck with the 2" drop front. Hope that all makes sense.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 01-10-2015, 08:25 PM   #2
UKNOWME
UKNOWME's Avatar
Re: Got a lowering question.
Based on what you are saying I would recommend spindles, shackles and hangers for a 2/4 drop.
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 01-10-2015, 10:35 PM   #3
rs74
rs74's Avatar
That's about what I figured. I just didn't know if it was better to do the spindles or springs up front or if it mattered. The back I wasn't really sure of. I flip kit would be more than what I would want. Thanks.
Roy
1987 R10 shortie
Old 01-10-2015, 11:53 PM   #4
MikeB
MikeB's Avatar
Using dropped spindles will preserve the ride, vs. shorter, stiffer springs.
However, I don't know if there are any wheel clearance, turning radius, or other issues with dropped spindles on 73-87 C10s. I can tell you that on 55-57 cars, some drop spindles increase the turning radius, and others offset the wheels outwards.
I'm looking to do 2/2 or maybe 2/4 drop on my short bed, so I am very interested in pros/cons of various lowering methods.
Mike
1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress.
1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 01-29-2015, 01:50 PM   #5
rs74
rs74's Avatar
Not sure about putting different hangers and shackles on now. I really don't want to take the factory hangers off and I don't want to trim the cross sills on the bed. There isn't alot of room between the factory shackle and cross sill now let alone putting on a longer shackle. I assume that is the only option here? May just have to go with a 4/6 and use the flip kit. Don't really want to go that low but I don't want to replace the hangers. Would rather leave them on in case I want to raise it back up and not have to swap out hangers again. Any other options.
Roy
1987 R10 shortie
Old 01-29-2015, 02:14 PM   #6
Slonaker
Insert Witty Text Here
Slonaker's Avatar
I used drop spindles on the front of mine with drop leaves on the back (both from Western Chassis) for a 2.5/4 drop. The only issue I noticed was a reduction in cargo capacity. I drove it daily like that for 8 years or so, and used it to move almost everything I owned when I moved out to the country. I also regularly towed a 17' center console fiberglass boat with it. You can see pics in my photo gallery link in my signature line.
Slonaker
EDIT: I went with drop leaves for the same reasons. I didn't want to cut the bed, and I didn't want the hassle of cutting the hangers off.
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 01-29-2015, 02:26 PM   #7
85/Silverado
85/Silverado's Avatar
Do you have photo's of the back underside so we can see what it looks like done?
Jack
85/Silverado is offline   Reply With Quote
Old 01-29-2015, 02:41 PM   #8
Slonaker
Slonaker's Avatar
Photos showing what? I sold the truck 2 years ago, so I can't go take anything new.
Slonaker
Stock '01 Silverado
Old 01-29-2015, 03:05 PM   #9
Keith Seymore
Keith Seymore's Avatar
For discussion purposes - what's the concern with cutting springs?
I've done probably a dozen or so squares that way.
My current '87 has been a daily driver for 29 years and 200,000 miles with no issues.
So - if you are like me - I wouldn't expect any problems.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 01-29-2015, 03:56 PM   #10
Malo83
Cruzzzn' Vet
Malo83's Avatar
K
I'll second that, my 83 has been running with 2 cut coils with no problems for the last 31 yrs
Malo83 is offline   Reply With Quote
Old 01-29-2015, 07:26 PM   #11
rs74
rs74's Avatar
I'm not saying it's bad. I guess it's just my preference to put the spindles on as opposed to cutting the springs.
Roy
1987 R10 shortie
Old 01-29-2015, 08:41 PM   #12
Slonaker
Slonaker's Avatar
Same here. I'm not opposed to cutting off a coil or so. it's fine as long as you don't get carried away. I would still prefer to use a drop spindle if I can, though.
Slonaker
Stock '01 Silverado
Old 01-29-2015, 11:57 PM   #13
UKNOWME
UKNOWME's Avatar
Do you plan to haul with it?
1964 Chevy c10
Old 01-30-2015, 12:06 AM   #14
rs74
rs74's Avatar
It will see light duty stuff but if I need anything heavy I will use the dually.
Roy
1987 R10 shortie
Old 01-30-2015, 12:37 AM   #15
MikeB
MikeB's Avatar
Cutting a coil off a spring makes it stiffer. If it didn't, the suspension would bottom out. Same is true of dropped springs that you can buy. A stiffer spring means a harsher ride. And with the spindle side of the A-arms sitting higher, suspension and steering geometry is out of whack -- parameters like shock angle, steering axis inclination, scrub radius, and other things I know very little about.
Now if the stiffer ride doesn't bother you, and you don't feel any difference in handling or braking into a turn, then the above issues don't matter. I'm sure dropped spindles affect front end geometry, too, but not as much, since A-arms stay at the correct angles.
On another note, where can I find pictures and/or instruction for installing shackles and hangers? I'm trying to get an idea of what needs to be done and how it all goes together.
Mike
Old 01-30-2015, 03:12 AM   #16
Jlo1986
Jlo1986's Avatar
Here are my two 86 Silverados. They are both dropped 4/6, with spindles and flip kit/c notch in the rear. Black truck has 15" rallys and the Blue truck is on 20's. They both ride smooth.
Jlo1986 is offline   Reply With Quote
Old 01-30-2015, 03:40 AM   #17
Gregski
Gregski's Avatar
this LMC Truck page can give you some ideas, I think if you don't want to cut your springs you can buy their already shorter springs and as long as you also get their shorter shocks you should be able to drop the front 2" inches without the pricey drop spindle set, and shorter shocks, hangers with shackles will drop the rear 4" inches
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=60
Gregski is offline   Reply With Quote
Old 01-30-2015, 03:46 AM   #18
Gregski
Gregski's Avatar
K
I believe it changes the spring rate and unless you heat up and bend the bottom loop a bit (like it was on the part you cut off) just cutting the spring reduces the amount of contact area on which it sits, from I don't know like 240 degrees of contact to less than 180 maybe
Old 01-30-2015, 01:48 PM   #19
MikeB
MikeB's Avatar
Got the shackle and hanger deal figured out now. Found some information on DJM's website.
Even though they sell dropped springs, they still mention geometry issues caused by the A-arms sitting up higher. One problem is an increase in negative camber, which you may or may not be able to adjust back to spec. Plus with the tie rods ends being tilted upwards, steering geometry goes to he11 in a handbasket.
Mike
Old 01-30-2015, 03:05 PM   #20
school boy
school boy's Avatar
The only problem I have and read about with drop spindles are:
1) 3 drop spindles cant run factory 15x8 ralleys or any 15" wheel with same backspacing
2) 2.5 drop spindles, some have rubbing issues but can be fixed (only factory 15x8 ralleys or any 15" wheel with same backspacing). I have ralleys with 2.5 drop spindles and my wheel weights rubbed the tie rod ends. I have heard some ppl running ralleys needing to trim their lower control arm. If all else fails, you can run a 1" spacer with the ralleys.
3) 2" drop spindles, heard/seen no problems so far personally.
Hopes this helps
school boy is offline   Reply With Quote
Old 01-30-2015, 04:25 PM   #21
MikeB
MikeB's Avatar
school boy -- thanks for the info. Just what I am looking for.
Mike
Old 01-30-2015, 04:33 PM   #22
Malo83
Cruzzzn' Vet
Malo83's Avatar
Who sells 2" drop spindles? i'm interested
Old 01-30-2015, 06:12 PM   #23
school boy
school boy's Avatar
http://www.ebay.com/itm/MCGAUGHYS-2-...334822&vxp=mtr
I guess seeing this confussed me! Says in title 2" drop but in details 2.5" drop. Fail on my part!
