Loctite blue
I am installing a engine (SBC )in my 1969 GMC truck and I was wondering do I need to use Loctite Blue on the engine mounts, bolts on flex plate and torque converter, and bolts in Bell Housing.
![]() Join Date: Jun 2012
Re: Loctite blue
I have always used loctite on the converter and flexplate but never used it on motor mounts or bellhousing..
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker ![]() |
![]() Join Date: Jan 2012
Re: Loctite blue
x2 vidman
It builds on my intelligence when I make a mistake, Boy am I building on it! '67 C-10,'70 Nova SS ![]() |
motor exploder
Re: Loctite blue
I used Loctite Red on my flywheel (at the crank flange) and pressure plate (to the flywheel). I did not use it on my scattershield or motor mounts, but I did use lock washers.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! |
