Drop spindle kit - which one
So, I've done some searching here, and I'm looking to get a drop spindle kit possibly.
I want to convert to disc up front (64') but don't want to spend the $$ on new wheels right now. I've got 15" rims, so that means 12" rotors is what I need. Here are my questions: 1) I've read many bad things about CPP, a couple about McGaughy's - what have you guys used? I plan to stick with my 64 control arms/steering linkage for now and thus don't want to do ball joints (mine are new MOOG anyhow) 2) Is it really worth it to just purchase a kit? Rotors/calipers/pads/misc. hardware are really just standard parts from later trucks...for those of you that have pieced them together, would you do it again or drop 600 on a kit? |
![]() Join Date: Jan 2011
Re: Drop spindle kit - which one
What I did on the 65 was just order the spindles to fit the a arms. Then went to the junk yard and got the splash shields. Order the 6 lug rotors from Summit as they have the best price. get new calipers, pads hoses, hard lines and bolts from the auto parts store. Ge the adapter bracket from Captain fab here on the board and get a new or used booster (lots of options) and a new master cylinder and do the power brake conversion. All told I had about $500 in doing it all.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
#4 | |
Looks great! Modular CPP spindles with 13" brakes? |
No, that's the non-modular 2.5" drop spindles and 12" rotors with Wilwood D52 calipers.
67-72 parts collector,…
![]() Join Date: Nov 2002
Buy 63-70 conversion spindles from ECE or McGaughys or Belltech.
The rest can be purchased locally. Look at companies that off free shipping.
I saw wilwood and assumed larger brakes. So they're dual piston and mount up to CPP drop spindles? This is the type of info I'm looking for - if I can source higher quality stuff and be another 100 into the swap I'll be happier than settling for essentially stock parts.
You will need to run new hard line to the hoses where they come to the frame in front of the a arm with the disc. Will need a proportioning valve. And yes I got new caliper bolts locally. Are you going 5 lug or 6?
Jimmy
#9 | |
I'll be going 6 lug - truck will have larger diameter steelies eventualy. Currently has 15" aluminum drag's. I was originally looking at using the CPP modular spindle, but came across a thread on grafting C5 brakes to any of the spindles. I need to look into geometry now - I know the CPP pulls tires in which I'll need to clear my fenders. Need to see if ECE/McGaughy's does the same |
Anyone bought from Tucker's Classic parts? Their prices are about $150 cheaper than CPP. Just wondering if they are "cheaper" materials or just selling at an honest price. CPP seams to have raised prices since the last time I was looking at the disc brake kits.
Well I just spent an hour searching for info on these...again. Seems no one can tell whether or not the CPP modular units actually pull the tires in. Anyone running McGaughy's on a 60-66 that can chime in on fender clearance?
#12 | |
Thanks for any and all help! Greybeard |
#13 | |
You can buy aftermarket 6-lug rotors, or oem 71-87 HD rotors locally. Add HD calipers, and bearings. The bonus to using the conversion rotors, is that they will work with the oem 63-70 ball joints and outer tie rods. I try to use an oem 71-72 master cylinder and prop valve (or an aftermarket equivilent).
#14 |
Thanks, your whole drum to disc page was great info for us. I have been keeping eye out for 73 up front end to rob whole a-arm steering arms and be able to readily get later model parts down the road- almost foregot the whole tie rod debacle. OUr 69 has PB and PS now, have a master, and proportion valve from 74 that is disc/drum 3/4 ton truck. Had planned on plumbing those in on my 69 with whatever disc setup we come up with. Thougth if we use OEM calipers, that 74 master and its bore should be OK. I went through the bore/pedal feel/caliper volume thing on the last street rod.
Thanks again! PS your red truck makes me want to keep our 6 lug truck rallies!! sweet |
