Old 01-11-2015, 12:39 AM   #1
BigRed76
BigRed76's Avatar
Sources for 2.5" heater core for a/c truck?
Are there any vendors currently making 2.5" heater cores for A/C trucks?
I have the original Harrison in my '70 GMC that started leaking (rotted on the corner due to leaves and dirt in air box), so I had it repaired but it didn't hold up very long so now I'm looking to just replace it. Thanks, Zach
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 01-11-2015, 02:43 AM   #2
elimontfort
elimontfort's Avatar
Re: Sources for 2.5" heater core for a/c truck?
Rockauto has 4 different ones available. I just got one from them.
elimontfort is offline   Reply With Quote
Old 01-11-2015, 02:44 AM   #3
mechanicalman
I don't know of any 2.5" ones.
O'Reilly's sells a replacement for your truck for just over $30 (2" core). It's aluminum so despite being thinner it will likely heat better.
http://www.oreillyauto.com/site/c/de...2709&ppt=C0331
mechanicalman is offline   Reply With Quote
Old 01-12-2015, 11:25 PM   #4
BigRed76
BigRed76's Avatar
I've wondered about getting an aluminum heater core... I mean if an aluminum radiator is better for heat transfer in the cooling system then it would do better as a heater core too right?? And I've seen that most vehicle made within the last 15-20 years have aluminum heater cores and they have awesome heaters.
Zach
Old 01-12-2015, 11:26 PM   #5
BigRed76
BigRed76's Avatar
I've looked at those available from rockauto but they are all listed as 2" thick, not the factory 2.5" thick.
Zach
Old 01-13-2015, 12:10 AM   #6
Acorn
I searched high and low for a vendor that sells a 2.5. Never found one.
Local radiator shop said he could try to re-core mine but it cost way to much.
Ended up getting one from gmcpauls.
Get brass. Will hold up longer and heat better.
Google search brass vs aluminum heater core. (Not radiator)
Hope this helps
The bitterness of poor quality lingers long after the sweetness of a low price is forgotten.
Acorn is offline   Reply With Quote
Old 01-14-2015, 12:44 AM   #7
BigRed76
BigRed76's Avatar
Hope this helps
I took your advice and did some research on brass/copper vs. aluminum heater cores, seems that brass/copper cores are proven to provide better heat dissipation.
And it seems I'm going to have to settle for a 2" thick heater core, which I'm sure will still heat the cab just fine, but I have read about fitment issues with the 2" thick heater cores...
Zach
Old 01-14-2015, 12:52 AM   #8
Acorn
As far as making it fit, I just used some foam pipe insulation in between the brackets and tank.
Old 01-14-2015, 09:43 PM   #9
BigRed76
BigRed76's Avatar
Good to know. Does it still blow pretty hot with the 2" core?
Zach
Old 01-15-2015, 06:49 PM   #10
jdw
Copper dissipates heat slightly better than aluminum, but both far out perform brass. And copper costs the most, so probably most of the repro heater cores are going to be brass in brass/copper mixes. Also probably why modern cores are made from aluminum.
jdw is offline   Reply With Quote
Old 01-15-2015, 11:30 PM   #11
picklito
I had the same problem and ended up having a local shop recore it. It was around $80 but the guy was able to get what looked like an original type core. He did a great job.
picklito is offline   Reply With Quote
Old 01-15-2015, 11:46 PM   #12
BigRed76
BigRed76's Avatar
That's what I had hoped to have done with my original heater core, but none of the local radiator shops re-core heater cores, so they just "repaired" the leak. And then it leaked again after running for 30 minutes.
Zach
Old 01-18-2015, 12:04 AM   #13
BigRed76
BigRed76's Avatar
Well today I got a copper heater core from advance auto for $32. It was a 2" thick core as they all are, the width was 1/2" less too, but when I installed it in the heater box it still filled the entire opening so there was no air gaps around it. I had to bend the pipes a little to get them lined up, but other than that it fit pretty decent. It seems to put out just as good of heat as the original heater core so I'm pleased with it.
Zach
Old 12-27-2015, 11:47 PM   #14
mtdave2
newly minted old timer
mtdave2's Avatar
Sorry to resurrect an old post but I'm wanting the same info. Has anyone started making a core that matches oem?
72 c20 longhorn 65k org miles and counting!
69 k10 Suburban
mtdave2 is offline   Reply With Quote
Old 12-28-2015, 12:26 AM   #15
snipescastle2
snipescastle2's Avatar
Talking Re: Sources for 2.5" heater core for a/c truck?
I have a spare "Harrison" heater core from my '71 build....it's for an A/C cab.......I'll take a few pics tomorrow if you're interested.....$30 plus the postage....sound good?
Let me know.
Ben Smith
snipescastle2 is offline   Reply With Quote
Old 12-28-2015, 12:42 AM   #16
BigRed76
BigRed76's Avatar
I haven't paid much attention since I installed my heater core in January. I will say that I've been driving the truck pretty regularly for the last few months, since the weather has gotten pretty cold here, and the 2" repro heater core has done just fine. It heats well enough that I have to turn down the heat because I will get too hot, and that's with it being 10 degrees outside.
Zach
Old 12-28-2015, 02:56 PM   #17
davepl
davepl's Avatar
If I had mine to do again I'd get my big fat original Harrison recored. The biggest unit I could find in reproduction (didn't check RockAuto, should have) is under 2" and I have to shim it to keep from flopping around. Not ideal.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 01-03-2016, 11:35 PM   #18
mtdave2
mtdave2's Avatar
Let me know.
Ben Smith
Fill me in on the Harrison core, is it the same as the orginal?
69 k10 Suburban
Old 01-04-2016, 12:39 AM   #19
chewychevy67
Harrison is the oem maker of the originals. I believe rads too. I had both my Harrison 4 core rad and heater core record by a local shop. It was a little costly but my heater core fits as it should. I too bought a aftermarket one and it needed shiming. Once those get loose the pipes get stressed and start to leak. For me it must fit 100% the way the factory made it to fit.
chewychevy67 is offline   Reply With Quote
Old 01-05-2016, 09:13 AM   #20
snipescastle2
yeah, the Harrison core I have is an original heater core from a 71' with air, I can take some pictures this evening after I get home from work if you like....
Ben
Old 01-05-2016, 01:45 PM   #21
kehstr
kehstr's Avatar
I know car quest auto parts makes them, just bought one from them
kehstr is offline   Reply With Quote
