Old 01-11-2015, 01:12 PM   #1
scott657
scott657's Avatar
Trans oil sag 4 speed
I'm dropping a used Saginaw 4 speed into my 63 c10.
What is the proper / best gear lube. I read the gl5 may be harmful to the brass parts.
Thank you.
Scott
63 C10 Stepside
230 1bbl
Saginaw 3 spd
scott657 is offline   Reply With Quote
Old 01-11-2015, 05:38 PM   #2
frankslagoon
Re: Trans oil sag 4 speed
the GL5 container says it helps bronze bushings. lots of guys use it. I've been playen with saginaws for 45 yrs. and just use the same thing as I put in the rear end. makes life easy. I have a 63 with a Saginaw 4 sp. and I'm usen GL 1
frankslagoon is offline   Reply With Quote
