Old 01-11-2015, 09:09 PM   #1
scatesracing
Machinist
scatesracing's Avatar
mpg z71
What kind of mileage is everyone getting with there z71s? I knew my 2002 was getting bad but i took time to figure on this last tank. 9.1 mpg. It runs so good its hard to belive anything would be wrong. I think i might throw a set of o2 sensors in it see if that helps. It only has 100k miles on it
scatesracing is offline   Reply With Quote
Old 01-12-2015, 07:05 PM   #2
69gmcc10
69gmcc10's Avatar
Re: mpg z71
Ethanol percentages in fuel go up in the winter to help with emissions, that might be your problem.
I would leave the O2 sensors alone and get an air filter, a bottle of fuel system cleaner and a custom tune for a better use of your $$$.
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676
03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582
69gmcc10 is offline   Reply With Quote
Old 01-12-2015, 07:39 PM   #3
Blown06
Blown06's Avatar
Re: mpg z71
My 2006 with a 5.3 and 4:11 gears gets about 15 ~ 16 on the highway. Was closer to 20 mpg with the stock 3:42's.
Me: Jarrod
My project: http://www.67-72chevytrucks.com/vboa...d.php?t=646563
Blown06 is offline   Reply With Quote
Old 01-13-2015, 10:49 PM   #4
scatesracing
Machinist
Re: mpg z71
I hate to think a little Ethanol would cut the mileage in half. its also never done this any other winter.
Old 01-14-2015, 01:35 PM   #5
69gmcc10
69gmcc10's Avatar
Re: mpg z71
Ethanol is a cruel and unpredictable mistress. By law, in the winter here the "only!" fuel you can buy is ethanol and in my 6.0 my economy in town drops from 13ish to between 8-9. Also other things to think about other than just crappy crappy ethanol blended fuel is idle time to warm up. Sure, it doesn't take much fuel to sit and idle, but with the extra time to warm up the engine, the computer to cut back the fuel after initial start up and the amount of time you should take before driving in real cold temps all have an effect on economy.
I would try some sea foam in the fuel tank (cleans o2 sensors and injectors), clean the MAF sensor with "MAF cleaner", and check my air filter. All that stuff is cheap, good o2 sensors are expensive in comparison. But no matter what you do you will still be running crappy, crappy fuel with ethanol in it and in cold temps probably a little water from condensation.
Old 01-14-2015, 06:42 PM   #6
scatesracing
Machinist
Re: mpg z71
Its just weird. it runs great! My 08 and my 99 still seem normal. Ill try some sea foam. the air filter is new. if that dosnt do it I am getting ready to buy HP tuners for my ls swap 69. I may get it sooner to find the problem on this truck.
Old 01-18-2015, 12:47 PM   #7
kaycee
kaycee's Avatar
Re: mpg z71
Did you change gas stations ? I used 1 that was allways a cent or 2 cheaper than anyone else, started using a different 1 and seems to run better. I don't know maybe it's just me but something changed . Are you running the low octane run some of the super through it.
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327
kaycee is offline   Reply With Quote
