Old 01-12-2015, 08:25 AM   #1
Mr Banshee
Need Help/Advise Body Mount Replacement
Began doing a body mount replacement. Found that my mounting on the rear sill and rear bed floor is badly rusted out. I'm in the process to remove the rear cross sill to fabricate a new sill with the mounting pads. I found when removing the spot welds and lower bolts that the inner structure behind the tail lamp that the rear cross sill bolts to is completely rotted out. I was looking for a patch panel of some sort for this but all I found was the tail lamp rear corner sheet metal for the outside. I know I need to remove the outer bedside (quarter panel) to repair this. Does anyone know of a repair patch panel available or have some insight how to repair this piece of structure? I can post some pictures of what exactly I'm talking about if need be. Thanks Mike
Mr Banshee is offline   Reply With Quote
Old 01-12-2015, 09:22 AM   #2
jaros44sr
jaros44sr's Avatar
Re: Need Help/Advise Body Mount Replacement
Mike, i think you re in a tight spot, because i have never seen a patch for that area. I would suggest posting a ' WTB' in the classifieds. Someone will have a piece for you
Good luck, and post up some pics
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 01-12-2015, 03:29 PM   #3
SeventyOne
Pictures will help.
SeventyOne is offline   Reply With Quote
Old 01-12-2015, 04:05 PM   #4
1rippen6
If you are talking the support structure at the taillight end of the quarter panel then look at the link below. I can get better pictures if you need it let me know.
http://67-72chevytrucks.com/vboard/s...d.php?t=640114
1rippen6 is offline   Reply With Quote
Old 01-12-2015, 04:24 PM   #5
Mr Banshee
Thats exactly what I'm referring to. I'm going to begin pulling the outter quarters off so I can see how much of that structure I will need and I can post some pictures to show detail. If you have some or can take some pictures with out to much trouble so show more detail that would be great and if you have these pieces that would be even better, save me from fabricating something up, specially since there appears to alot missing. In addition thats what i can only see thru the taillight area, I'm sure its alot worse behind the quarter. Thanks again Mike
Old 01-12-2015, 04:32 PM   #6
1rippen6
Pictures are not a problem will get them tonight. I actually cut most of the sheetmetal off now so you can get a good look at everything. One is in real nice shape the other has a hole about the size of a golf ball if I remember right but should be an easy fix. A lot easier than trying to fab. the whole thing. Both pieces are for sale 40 ea. plus shipping.
Old 01-12-2015, 04:36 PM   #7
Mr Banshee
Sounds good, If you need to get a shipping quote, I'm in Warren Michigan 48008. Thanks Mike
Old 01-12-2015, 10:49 PM   #8
1rippen6
23 for shipping so 103 total shipped let me know if interested.
Old 01-13-2015, 11:20 AM   #9
Mr Banshee
IRIPP6, looks good I'll take em! PM me the details for payment to you and I'll get that off. Thanks Mike
Old 01-13-2015, 11:27 AM   #10
1rippen6
Pm sent
Old 01-13-2015, 11:59 AM   #11
Mr Banshee
Payment Sent! Thanks, Mike
Old 01-13-2015, 12:20 PM   #12
1rippen6
Received will box up tonight and should ship out tomorrow. Thanks
Old 01-17-2015, 11:52 AM   #13
Mr Banshee
Irippen6, Received the posts this morning. Everything was perfect. I would have had a challenge to reduplicate these since alot of mine was gone. Exactly what I needed. Thanks for everything, Mike
Old 01-17-2015, 02:36 PM   #14
Chulisohombre
Chulisohombre's Avatar
Was reading through and saw this. I was thinking only way to get them was the way it worked out for you. Glad you found some. Rip the rig they had to come off of to fix yours. At least a piece has gone in to fix a good existing truck. If worse case scenario you could have used a old truck bed and cut those ends out I think they are the same. I'd like to see some pics of how you do the repair.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks.
Chulisohombre is offline   Reply With Quote
Old 01-17-2015, 02:41 PM   #15
1rippen6
Good to hear
Old 01-17-2015, 02:43 PM   #16
1rippen6
That is correct trucks are the same the green one was a super nice truck bed that was sideswiped and the blue one was a blazer that was also wrecked.
Old 01-17-2015, 09:28 PM   #17
Mr Banshee
Chulisohombre, I have a build thread under Projects and Builds named Project Blazilla. I'll post pics of progress on these rear pillars sometime in the next week. Working on pulling the first quarter off to get the rear cross sill out and start the pillar extraction. Follow the progress there. Thanks for the interest.
Old 01-17-2015, 09:49 PM   #18
Chulisohombre
Cool. I'll try and find it.
