Old 01-12-2015, 07:28 PM   #1
Dalaigh
Canadian Trucker
Dalaigh's Avatar
1991 chevy's hazards not working…
I picked up this 1991 C2500 last week and today just took it to see what it needs for safety. The only thing that needs to be fixed are the hazards, they don't work but the turn signals do. I'm assuming there is a flasher for the hazards, but just incase someone has had this problem before, is there somewhere else I should be looking…
2020 Silverado Trail Boss - 6.2/10spd
Dalaigh is offline   Reply With Quote
Old 01-12-2015, 10:47 PM   #2
4x4toy
Re: 1991 chevy's hazards not working…
Cycle the switch repeatedly fast, they get dusty and the lube gets hard in switch from being on top of column.
04 Yukon XL 2500 w/ Quadrasteer
61 Chevy C60, 261 inline six
86 Chevy C20 2wd, Banks 6.2
05 GMC Sierra 2500hd Duramax
4x4toy is offline   Reply With Quote
Old 01-16-2015, 04:15 PM   #3
Dalaigh
Canadian Trucker
Dalaigh's Avatar
Turned out to be the flasher, so for $14 the $900 truck is safetied…
Old 01-20-2015, 09:33 AM   #4
68 TT
Still plays with trucks
68 TT's Avatar
Glad you got it fixed.
The hazards will also stop working if the brake light fuse is blown. I had a trailer light harness short out once and it would pop the brake light fuse if you hit a bump and the trailer harness moved just right. The white wire was grounding out against the trailer hitch where the PO had zip tied it too tightly with no wire loom covering to protect them. Chased my tail on that one for a while.
Not the same problem as you had since your brake lights worked but I figured maybe this might help somebody else out.
Hope you enjoy your truck.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
68 TT is offline   Reply With Quote
