Old 01-12-2015, 08:34 PM   #1
aod92
aod92's Avatar
Painting a frame question?
I'm gonna have the body off the frame of my 67 c10. The frame is pretty clean but I would like to get a fresh coat of paint on it. I'm gonna wire wheel it first to get any loose paint and rust off. What are you guys using to paint your frames. I'm thinking about por15 but I heard it has to be top coated. Any other good paints out there that would be good for a frame that wouldn't have to be top coated? Thanks guys!
aod92 is offline   Reply With Quote
Old 01-12-2015, 09:19 PM   #2
alltexan
alltexan's Avatar
Re: Painting a frame question?
I sprayed my frame with implement paint from tractor supply.......I couldn't afford por 15 or powder coating at the time. I put five coats on it and the paint turned perfect and hard as a rock. I'm reassembling it now without a scratch......just my opinion if you are on a budget
alltexan is offline   Reply With Quote
Old 01-12-2015, 09:23 PM   #3
EARNHARDT#3
EARNHARDT#3's Avatar
Considering sunlight won't be shining on your frame I don't think you'd need to top coat POR15
EARNHARDT#3 is offline   Reply With Quote
Old 01-12-2015, 09:33 PM   #4
aod92
aod92's Avatar
I know it's a matter of opinion but do yo guys think it should be gloss black or satin?
Old 01-12-2015, 11:12 PM   #5
alltexan
alltexan's Avatar
Satin is what I sprayed.....I figured gloss was too hard to keep clean ....but in the end you will do whatever makes you happy
Old 01-12-2015, 11:28 PM   #6
davischevy
davischevy's Avatar
For a truck I'm going to drive, I use Rustoleum code 7777 satin. It comes in cans for your gun and spray bombs for touch up.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 01-13-2015, 12:22 AM   #7
68shortwide
68shortwide's Avatar
Please tell me you're not gonna touch the awesome paint on the body and implement paint works, or I've heard Eastwood had somethin for frame paint. I'll try n look up the thread. Edit: apparently Eastwood is crap when it comes to frame paint. I'd say por15 or implement or rustoleum is your best bet.
Jack
1968 swb on air
68shortwide is offline   Reply With Quote
Old 01-13-2015, 12:32 AM   #8
87Skier
87Skier's Avatar
I used Chassis Saver, it's a lot like Por15. $40/quart, but a quart would do your whole frame. It can be sprayed or brushed on. I brushed mine and it came out pretty good.
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205
1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears
1996 Chevy Suburban K1500 350/4L60E
87Skier is offline   Reply With Quote
Old 01-13-2015, 12:39 AM   #9
KMC3420
KMC3420's Avatar
I used eastwood extreme chassis black single stage. I sandblasted, epoxy primed, and followed up with chassis black. As long as you have a solid base that's clean you should be good. Your paint is only as good as your prep. Chassis black isn't bad but opt for the 2k if you do, not the single stage. There are many options when it comes to paint. Good luck.
Keagan
68 SWB C-10 original 350 A/C 503 Mean Green
KMC3420 is offline   Reply With Quote
Old 01-13-2015, 06:01 PM   #10
aod92
aod92's Avatar
Lol...that I'm not sure on yet. My dad is a body and paint guy and he's dying to get his hands on the body lol
Old 01-13-2015, 10:24 PM   #11
brawley
Easy Does It
brawley's Avatar
I sprayed mine with satin black epoxy primer, bought a gallon from summit , i think it was around $40-50, used it on everything, cheaper than buying can after can
brawley is offline   Reply With Quote
