![]() Join Date: Aug 2003
wtb NP203 or trade for NP205
I am looking for a rebuilt NP203 or a very good rebuildable core. I am trying to build a doubler for my 69 swb. I have a working 4speed/NP205 that I pulled from my parts and would consider a trade or you can buy mine and I can buy a NP203 from a local shop. Let me know if interested.
Collector of rusty Items
Hmm..
You want to trade a 205 for a 203? No offense entended, but I think you are being too generous. 203's are a dime-a-dozen. I see one on eay for 30 bucks. http://cgi.ebay.com/ebaymotors/ws/eB...tem=2429090907 and if you buy it, have them throw out the back half and just ship the front. because all you need from the 203 is the front half, and that part never wears out, the chains die, but not the front. anyway, don't give away the farm. check out your local wrecking yard etc before you give up a 205. good luck
Scrub Sisters, Oregon - Home of the Sisters Rodeo. 70 GMC 1,000,000 + miles 72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends. |
thanks for the advice, i'll check out ebay. i haven't even started looking in the yards yet. i'll try that next
user # 2756
![]() Join Date: Jun 2001
As I understand you'll want to use your SM465 you'll want a 203 that was mated to the SM465. Then to mated the 203 gear reduction section to the 205 w/ an adapter, i think you'll want to get a 205 that was mated to an Turbo 400 it has the input shaft that does not use the collar and has finer splines 32 I believe. This might only be for the ORD 2nd gen doubler. I believe ORD does sell the parts needed(input shaft etc...) to make it work. Just something to consider while your looking for parts.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() |
As far as I know, which isn't that much, there were very few MS465 to 203 setups. They only came stock in 74 blazers, go figure, so they are hard to find. Mostly they were behind automatics, so you probably need an adapter. This site has really good info on the sm465 to 203 setup:
http://www.uoregon.edu/~jrice/NP205/Doubler.html or ORD has stuff to buy http://offroaddesign.com/catalog/doubler.htm another good site http://www.alaskaoffroad.com/tech_2.htm or http://www.high-impact.net/transmiss...ar/doubler.htm FYI High angle driveline has a patented front output flange for a 205, but I found a Dodge 205 case with a flange that will take a 1410 ujoint, and the back output shaft is a 1410 with 32 splines. I am just going to put the guts into a Chevy case. I stole that case and a 203 doubler box off ebay for 57 bucks.(no picutue on ebay and it sells too cheap) Also, there is a new CV joint on the horizon called a Bigelow joint that is supposed to be out in a few months. click on the Bogelow link here http://www.4xshaft.com/ Good luck
Led Sled! Discs R 4 ME!
![]() Join Date: Jan 2001
Hey diggy, I assume that’s you bidding on that T-case on ebay.
If so, I will not bid against you. If by chance not then let me know so I can find out about shipping. |
Life is Good !
i have a transfercase for sale, here is the info. I think it is a 203.
I have a transmission out of a 67 chevy 4X4, it is a 4 speed, I think with the rockwell transfer case, heres the # for the t-case, Model # T221N1 ratio 1.94 serial # 1266-1498 I would like to see a $100 but make me an offer, you pay shipping.
'72 Chevy C10 4x4 shortbed "Project" '71 Chevy C10 2wd longbed "partsrunner" '91 Chevy Burb 4x4 "kidrunner" '14 Honda Accord Sport "commuter" |
That's a Rockwell 221, and If it is in good shape, 100 bucks is cheap as parts are not made any more and they are getting hard to find. I would put it on ebay and see what you get. You might be surprised with a couple hundred bucks.
good luck
Life is Good !
is it a t-case? strong and such? I just pulled it out of a parts truck, I know nothing about it. any info you can give me?
