Old 01-13-2015, 09:45 PM   #1
hotrod66
hotrod66's Avatar
how much paint?
I want to paint the inside of my truck with actual auto paint from a gun ,but don't know how much to get? Also what else is required I am new to this paint thing, I am a wrench so please forgive me. Any help would be appreciated.
Between saying and doing many a pair of shoes are worn out
hotrod66 is offline   Reply With Quote
Old 01-13-2015, 09:48 PM   #2
bj383ss
bj383ss's Avatar
Re: how much paint?
I had a quart for the inside and I only got the top, dash, and back wall sprayed with 2 coats and the floor and firewall 1 coat and ran out. Made me so mad! I hate running out of paint. Still have to paint the inside of the doors too. So at least 2 quarts maybe 3.
Bret
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955
bj383ss is offline   Reply With Quote
Old 01-14-2015, 04:53 PM   #3
shortbed70
shortbed70's Avatar
Re: how much paint?
It all depends on gun type and paint. 1 quart of ppg single stage with reducer and activator would be plenty out of a good gun. If using a cheaper gravity fed gun with a stock cup you end up wasting some paint due to angle of application on the roof. I use pps (positive pressure system) with a good gun so I can spray at any angle. I would get two qts to be safe and reducers and activators. What brand of paint were you lookin at? I only have a Qt of house of kolor candy red to do the inside of my 65 so will c.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 01-14-2015, 05:05 PM   #4
Cape Codder
Cape Codder's Avatar
Re: how much paint?
Check with the paint mixer first to see if it is a color that covers well. Some reds and Yellows seem to require twice as much paint to cover. Also depends on how much contrast from primer to paint. Some painters tint the primer or sealer to make it cover better.
Cape Codder is offline   Reply With Quote
Old 01-14-2015, 10:59 PM   #5
hotrod66
hotrod66's Avatar
Re: how much paint?
Yea my gun is cheap,
I can get basf paint threw my work. I have watched a lot of paint jobs be done but have not done much my self I have only primed body panels. I am tired of having good running ugly trucks. Thanks for all y'alls help.
Old 01-15-2015, 09:27 AM   #6
shortbed70
shortbed70's Avatar
Re: how much paint?
If I rememeber correctly BASF is a 4-1 mix on bascoat clearcoat so two qts should be plenty depending on color. if it's a lighter color then get 3. Single stage might be the way to go for you just don't know the mix ratio off hand for it but ss paints tend to cover better with cheaper guns. Lay your first coat kinda light maybe a 30% overlap in coverage then on the second go with a 75% overlap and go slower to achieve that nice wet look.
Troy
Big Red Dog build
Old 01-15-2015, 09:56 AM   #7
bj383ss
bj383ss's Avatar
Re: how much paint?
I used ss urethane and the mix is 4:1:.5. Its Hot Rod Flatz.
Old 01-15-2015, 11:26 AM   #8
cooperhw
cooperhw's Avatar
Re: how much paint?
I will also vote for 2 qts. It's nice to have a little left over (for touch up or whatever) as opposed to running out.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
