Old 01-14-2015, 09:47 AM   #1
1972 Jimmy
1972 Jimmy's Avatar
1972 350 Harmonic balancer help
Hello all,
Need some help determining what is the factory correct harmonic balancer for a 1972 350ci in my 4x4 jimmy. I'm not sure on the diameter or thickness. If anyone has the casting or part numbers the would be great as well!
Thanks,
Eric
1972 Jimmy is offline   Reply With Quote
Old 01-14-2015, 08:07 PM   #2
1972 Jimmy
1972 Jimmy's Avatar
Re: 1972 350 Harmonic balancer help
Anybody???
Old 01-14-2015, 08:48 PM   #3
davepl
davepl's Avatar
Part numbers are all in the part number books. I will guess 12551537 but you'd have to look up your own truck.
I found 10 on RockAuto.com, so not to be "that guy", but Google first.
Long story short (more experience mechanics can correct me here if I'm wrong) the 350 is a neutral balance engine so as long as it fits your crank snout the only question you really need to answer is how much you want to spend.
You can pick up a Dorman brand new for $30.
You can spend $500 on a liquid-filled, SFI approved, turbocharged 3D version.
It is my understanding that with a neutral balance engine you could run a 6.75 inch or an 8 inch (or pretty much anything that is also neutral balance). I imagine your original is 6.75 by 2.375 and just over 8 lbs. But there are HD optional ones, 8 inch replacement ones, and so on.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 01-14-2015, 11:41 PM   #4
WIDESIDE72
WIDESIDE72's Avatar
If you have the original short water pump you will need to run a 6.75" balancer. The 8" will interfere with the swp. If you have a swapped in lwp you can run either from a clearance standpoint, but im not sure about pulley alignment. I try to keep mine all either swp/6.75/ swp pulleys/ swp brackets or lwp/8"/lwp pulleys/ brackets.
WIDESIDE72 is offline   Reply With Quote
