Old 01-15-2015, 02:33 AM   #1
twistedchevy
twistedchevys build
Everyone has a new years eveloution for things such as eating health to drinking less or being more active to whatever. Mine was buying a burn before 2016
So 3 days in I found one:
1972 Chevrolet c20 suburban, SBC 350, turbo 350, factory a/c front and rear, 50gal fuel tank, late model wheels and rear bumper.
It's missing all of the a/c parts under the hood, pass rocker panel has some rust and needs replaced along with some rust in the rear driver quarter that can be fixed. Was missing the rear hatch win do but my dad had a spare.
Jan4 swapped ignitions with one with a key, charged the battery and started it up after sitting for 2yrs. This weekend I'll be replacing the dry rotted tires, porportioning valve, plugs and wires. Also will be installing an electric choke on my Manuel choke edelbrock carb.
Also been trying to sort through the hacked wires from the previous owner.
twistedchevy is offline   Reply With Quote
Old 01-15-2015, 12:10 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: twistedchevys build
Looks like a good one. I'm diggin' the cab lights, I've always wanted a truck with cab lights but so far it hasn't happened....
LockDoc
Leon
Old 01-16-2015, 01:47 AM   #3
twistedchevy
LockDoc
Thanks, I love them, I have to replaced all the seals on them though and some of the lenses are cracked so I'm going to have to basically buy new ones.
Old 02-01-2015, 01:40 AM   #4
twistedchevy
01/03/15
Bought it
01/04/15
changed ignition, charged battery, changed fuel filter, lubed all hinges, cleaned out most interior and replaced front calipers and front brakes
01/10/15
Removed glove box, glove box door, and stereo. Chased down both additional switches on gauge cluster(driver side has been spliced into rear ac wires, pass side goes to throttle pedal for poor man choke)
01/11/15
replaced rear hatch(upper portion)
01/17/15
Painted battery box and underside of hood. Taped up wires going to pass headlight and marker light. Replaced distributer thing
01/18/15
installed electric choke, new tires and carb adapter. replaced spark plugs, valve cover breather and proportioning valve.
TOOK ON FIRST TEST DRIVE
temp gauge doesn't work, amp gauge doesn't work, thermostat should be replaced, radiator cap leaks, used proportioning valve is bad, speedo gear is wrong, steering column out of adjustment, exhaust rattles by gas tank, needs wipers and pass headlight bad.
01/24/15
replaced proportioning valve, brake master cylinder and gauge cluster. Removed manual throttle cable, broken dash pad, broken a/c vent hoses and defrost hoses. Chased loose wires down.
01/25/15
replaced external regulated alternator for an internal regulated alternator(used), wipers and installed new thermostat gasket. installed window crank handles on rear driver, rear passenger and front passenger. Painted alt bracket and air cleaner lid.
-test drove: engine head temp doesn't go above 160*F, carb needs rebuild and timing needs adjustment(bucks, pops and lags at full acceleration). Fuel gauge stuck past full, temp gauge doesn't work and amp gauge doesn't work.
01/31/15
*ignition module good.
replaced ignition coil and ignition condenser. Added 1quart of tranny fluid.
-drove on freeway, speedo is off need 1.3 multiplayer. Replacement of ignition coil caused bucking to disappear at full acceleration.
Old 02-01-2015, 12:35 PM   #5
LockDoc
LockDoc's Avatar
Sounds like you are moving right along. Where's the pictures???? Did it originally have a three hole cluster? If you changed it from a three hole to the gauge cluster, or someone before you converted it that may be why the gauges aren't working. The under dash wire loom is different for the two. Just a thought.
LockDoc
Leon
Old 02-01-2015, 11:12 PM   #6
twistedchevy
LockDoc
I'm trying, been to busy working on this and helping my dad moving all of his 67-72 parts to his new shop. No it came with the 7hole cluster, on the original cluster the temp gauge was pegged full hot now this gauge never moves off cold.
Old 02-01-2015, 11:20 PM   #7
twistedchevy
Drove the burb today, after parking it wouldn't start again, so the only thing left to be wrong is the pick up coil. Also found a 1.2 speedo multiplayer. But after cruising a couple of miles off the freeway, came to a stop at a light. Light turned green and started accelerating and heard an awful knock. Babied it a mile home, sounds like a spun bearing or bent rod. Only hear it when accelerating on a load. I guess the engine swap will becoming sooner. Nothing special, just a rebuilt 350.
Once my dad gets settled at his new shop we will tow the burb over and swap engines. While swapping engines I'm going to try and power was the engine bay, paint and clean up the wiring.
Old 02-02-2015, 12:02 AM   #8
Average Joe
Average Joe's Avatar
Always something, right? Hang in there,at least you got alot of the bugs worked out before this happened.
1967 C10 Suburban 454/TH400/3.07's
An Average Joe and His 'Burb:
http://67-72chevytrucks.com/vboard/s...d.php?t=775843
Average Joe is offline   Reply With Quote
Old 02-02-2015, 12:56 AM   #9
twistedchevy
Yea we were already talking about swapping engines before it happened.
Mine: 72 c20 Chevy suburban, 02 5.3 w/4l60e , factory ac and 50gal tank.
70 k10 Chevy burb, 04 5.3 w/4l60e np241, with dual 30gal saddle tanks and rear 30 gal tank
Dads: 67 c10 step side(project)
72 c10 GMC burb 350/400, with 67 Chevy front clip(grocery getter)
Ours: 67 c30 tow truck
70 c10 long bed 383stroker w/digital gauges(work truck)
Old 02-02-2015, 11:00 AM   #10
kev2809
low n' slo
kev2809's Avatar
thats the way it starts! then you will end up doing a full rebuild on the whole truck!
looks like you have a good one to start with...whats the overall plans for it?
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 02-02-2015, 05:33 PM   #11
twistedchevy
I want to make a crew cab eventually.
Old 02-16-2015, 10:54 PM   #12
twistedchevy
02/13/15
Had burb towed to the shop, pulled motor
02/14/15
sorted through some engine bay wiring and rerouted some wires. Installed motor, headers, p/s, alt, fan, radiator and aftermarket oil, p/s, alt, fan, radiator and aftermarket oil, volt and temp gauge under climate controls.
02/15/15
Welded exhaust to headers. started engine and broke cam in. Drove burb around. Need to rebuild carb.
02/16/15
Painted outside of hatch, tail light housings and reverse light housings.
The hatch after paint, nothing fancy yo can see where the hatch was rusting and where the paint was, but it looks much better
The reverse light housings before
And the tail light housings 1 before and 1 after 1coat, these got 3 coats
I think I will try and get some LED bulbs for everything outside eventually
Old 02-16-2015, 11:22 PM   #13
Joe Pass
Joe Pass's Avatar
Nice project
Joe Pass is offline   Reply With Quote
Old 02-20-2015, 11:27 PM   #14
engairuph
I'm curious about the 50 gallon gas tank? Is it dual or what has been added?
Ralph L. Jasper
69 4x4 Suburban PTO winch(NAVY)
13 GMC Ext cab
12 Ford Fusion SE(wife)
MAI
Interior shop
engairuph is offline   Reply With Quote
Old 02-21-2015, 12:57 AM   #15
twistedchevy
After reading a lot it may actually be a 45gal tank that was a factory option, I have found a lot of other guys on here that have the same tank.
Old 02-21-2015, 07:09 AM   #16
engairuph
I'll have to find one, the only one iseen for these are 15gal, 21gal tanks and then second tanks that are 12gal.
Ralph L. Jasper
13 GMC Ext cab
MAI
Interior shop
Old 02-22-2015, 12:55 AM   #17
twistedchevy
Replaced the carb and reinstalled the broken fan shroud with a temp patch.
Old 02-22-2015, 01:05 AM   #18
twistedchevy
Some pics
Old 02-23-2015, 12:35 AM   #19
twistedchevy
My dad found the fuel gauge wire hanging under the dash, he plugged it into the fuse block and my gauge started working. So I drove it around today for about 50 mile with no problems
Old 03-08-2015, 11:59 PM   #20
twistedchevy
Been just driving my burb around and enjoying it, cut my dash up this weekend for my new stereo that I am ordering
Decided to put the stereo where the ash tray was, I don't smoke and don't let people smoke in my cars.
I'm thinking about putting a cubby hole where the old stereo mounted, this is just a temp deck until the welding is all done
Old 03-09-2015, 12:07 AM   #21
twistedchevy
I also got a complete set of doors and back panels out of my dads old 70suburban that he parted out a few years ago. Found them in his garage today, will eventually pull the fabric off the metal and clean and paint the metal panels to get rid of the plastic panels I have, and will use the old back panels as templates for some metal ones.
Old 03-16-2015, 04:17 PM   #22
twistedchevy
Installed my new headlights and ballasts, also cleaned out the back and started painting the back. And set the rear panels in place to see what it would look like
Old 03-23-2015, 09:01 PM   #23
twistedchevy
03/21/15
Pig tailed headlight harness to new harness, ran tach wire(found tach is for a v6), found door panel upper mounts for both front doors and third door(need to find fake door mount) and ran new ac/defrost hoses under dash
03/22/15
Welded cubby pocket into dash, and welded spoiler mounting holes up.
03/23/15
Installed door panel mounts
So I need a new tach for a v8, a new volt gauge(hook 12v upland the gauge pegs max18v) and the clock doesn't work. So everything out of that camaro was bad. Go figure.
Old 04-19-2015, 12:40 AM   #24
twistedchevy
The before and after cleaning up the panel mounts side by side
04/04/15
Pulled the fabric off the door panels
Wire wheeled the panels
Primed door panels with some kilz(primer blocker and sealer)
04/11/15
Painted door panels, installed new-to-me door mirrors.
04/13/15
Installed door panels
04/16/15
Ran power wire from battery through dash to solenoid then to fuse box
04/18/15
Installed carpet in rear, painted rear a/c housing, bypassed dash light wire(spade on back of fuse block was shorted out) and bypassed rear a/c fan switch(bad switch and power wire hacked ran new power wire off new fuse block).
The rear a/c blower motor works awesome, on med I can feel air hitting the back of my head in the driver seat.
Only pic I have right now is the before of the rear a/c cover
And some pics of my dads and my suburban
Old 04-19-2015, 01:18 PM   #25
LockDoc
LockDoc's Avatar
Sounds like you are making progress.
LockDoc
Leon
