01-15-2015, 02:00 PM | #1 |
Cab mount bushing help...67 K10
bought new cab mount bushings, and cant seem to locate them where the cab sets right. They were ordered to fit 1/2 ton 4x4's and 3/4 ton 2x4. Placed where I think they should go, the cab has way too much forward rake. I wasn't sure if this was an odd '67 issue or I am overlooking something. Any help or bushing dimentions would be appreciated. Thanks, Jeff
Coop |
01-15-2015, 03:21 PM | #2 |
Re: Cab mount bushing help...67 K10
can you post a pic of the way you set up the front and rear mounts?
1967custom |
01-15-2015, 05:07 PM | #3 |
Jeff ,
Are you using the rubber or poly mounts , if poly I'm guessing the bushing is setting flush on the frame mount? The poly and the inner steel sleeve can be to thick not letting the bushing setting flush. This mybe not your problem but worth a look. Scott
1972 Custom Deluxe 20 4x4 burb 1971 GMC SWB CST 4x4 1972 GMC k20 4x4 (X- brush truck ) 1971 Chevy CST Blazer 4x4 1971 Chevy C/10 1970 Cab Chassis C30 157" 1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica ) 1988 Chevy V30 4x4 wrecker challenger 4812 |
01-15-2015, 06:03 PM | #4 |
these are the rubber ones. with the taller ones is the rear, which is where I thought they go, I cant seem to get a combination that's even close. I will post some pics tomorrow. thanks guys!!
Coop |
05-02-2015, 12:23 PM | #5 |
Did you ever get the bushings figured out?
