Show Me Your Aftermarket Tach's
Thinking about installing an aftermarket tachometer in the ol 68. Going for the ol school look. It's got a 250 engine with 3 on the tree.
Don't really want to mount it into the dash bezel. Show me pictures of where you mounted yours. Steering column? Dash mount? Thoughts? Thanks Guys As Always.
MyToys: Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles. Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop. Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ. Member of the Louisiana Classic Truck Club, LCTC Member of the Louisiana C10 Club Member of the Baton Rouge Drifters Car Club |
Re: Show Me Your Aftermarket Tach's
Screwed this one up
Can't figure out how to delete posts
Not sure why I keep screwing up these posts. Guess I am a Luddite. Sorry
Not a bad idea. Out the way but still visible. The ones with the shift lights are pretty cool.
Do you hit your leg on it?
That was my first concern placing it there but no my leg is not close at all. I'm 5"10 and a taller guy might not want it there but it's kind of to the side too so it would likely be ok for most.
Here's mine.
1968 Custom Camper C/20, rebuilt original 327 with 350 hp., turbo 400 with shift kit, factory AC truck, original patina rust free paint from Oregon, 2/4 lowering springs + 1" blocks, GM 2500 8 bolt rally's with dually center caps with Firestone Destination 245/75-R16's. (My 50th birthday present from my wife!!!) |
Boy, what am I doing here? Let's try this again...
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Its hard to see, a Sun Super Tach, but its on the column in front of the tach hole.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#13 |
Those are nice locations too. What size tach face y'all got?
#14 |
![]() Join Date: May 2014
Sun tach....
#15 |
In case you reconsider installing the tach in the dash. From what I can remember it didn't take alot of work to do. The tach is a Sunpro and the bezel was originally chrome but I painted it to match the rest of the panel.
#16 |
That looks pretty good too. What size face is that? 3"?
#17 |
It's a Sunpro Super Tach II. I think the specs say 3 3/8". I measured the face and it is around 3". It was a tight fit but I didn't have to cut the bezel at all. I just cut a hole in the clear plastic lens and the metal piece behind that.
