01-15-2015, 08:50 PM | #1 |
Help me choose a lowering kit
As per title i need a bit of help choosing a lowering kit for my 1971 C10
1st one is ECE 4-6 kit 4/6 Drop Kits (2.5" Drop Spindles, 1.5" Drop Front Coil Springs, 6" Rear Drop Coil Springs, 4 KYB Shock Absorbers, Super Track Bar Kit, Shock Mount Relocator Kit) (Drop Spindles require Disc Brakes) Cost $799 Looks like a good kit and i know it is recommended on here ( looking at the searches) but there is no mention of a C notch on the rear. 2nd one is Brothers 63-72 "ultimate" Suspension Kit - Drop Spindles This is it! If you want the ultimate ride, stance and handling from your classic, you want this kit! All of these items have been tested, both separately and as a complete package in a number of BROTHERS projects but most noteably on our Project 1971 Suburban. In this Ultimate Kit you get drop-spindles, a complete set of lowered springs, sport shocks and anti-sway bars. In the rear, we've included our custom lowering springs, 1-1/2" lowering blocks with U-bolts, bolt-in C-notch kit, shocks, and an anti-sway bar. This combination retains full suspension travel by the use of the C-notch kit in the rear and the drop spindles in the front. Cost $1379 It does not state how low it is on there site but i just called them and they say it is 4 1/2 on the front and 5 1/2 on the rear, confusing as it comes with a C-notch for the rear but it is not lower than the ECE 5 1/2 V 6" The brother kit does come with front and rear sway bars which i think is why the kit is more money. So any input guys Or recommend another kit
1971 C10 Short Bed Fleet Side 1990 Ferrari 348TB 2005 Ferrari F430 Too many 2 Stroke Motorcycles To List ! |
01-15-2015, 09:37 PM | #2 |
Re: Help me choose a lowering kit
I have the ECE 4/6 kit + their front swaybar. It's actually 4.5/6.25 after trading the kits front 1.5" drop coils for the 2" drop coils, and adding 1/4" rear drop blocks.
No complaints about the ECE kit. Handles much better now and looks good in my eyes. Good support from ECE, to fill in some blanks from the instructions. A few comments: - The c-notch is not required with the ECE kit (I have not had an issue in 1yr since the install). - ECE shipping is costly, so compare the shipping costs between the two. - The Brothers one sounds like it comes with front and rear sway bars. You can always add these later if you wish, with the ECE kit. Assuming the quality of the two is the same, I'd go for ECE at the lower cost. |
01-15-2015, 09:43 PM | #3 |
Eat, Sleep, Drive a Chevy
I bought my kit from CPP. no complaints, Infact I mentioned this site and the gave me a discount on shipping.
Have also heard many members rave about Early Classic. In my experience with Brothers, I have had to wait for many parts because they did not have everything in stock. Good luck
Trey Silence may be Golden, but Duct Tape is Silver! 72 Short Step 57 "big window" short step |
01-15-2015, 11:56 PM | #4 |
Active Member
I put an early classic 4/6 on mine. Went on without a hitch. Excellent quality and a great tech department. They recommend not notching the frame and just trimming the bump stops. I have never felt it bottom out in the year it's been on.
01-16-2015, 07:52 AM | #5 |
ECE all the way. They helped me piece together my set as I already had a few odds and ends. And when I wasn't happy with how the front was sitting, they sent me a new set of springs with a return shipping label for the first set... I did not ask them to do this as I did not think it was their fault, but they did it anyway.
I have 2.5 spindles in the front and 4" spring in the rear. I also have front and rear sway bars and shock relocates and the super track bar... I love the way it handles and the ride is not harsh. |
01-16-2015, 08:45 AM | #6 |
70+ ( Old Skool Club )
I've been on tis site since 2003 and have never heard a bad word about ECE their products are top notch and service the same. If you call ECE they will spend as much time as necessary talking with you and to figure out a suspension plan for your truck.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
01-16-2015, 09:20 AM | #7 |
if I was going static drop, I'd go ECE for sure. When I got my first truck I looked at most kits and even talked to ECE. Great guys to deal with and read nothing but praise about the quality of their product.
Ryan 1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840 1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628 1967/71 Blue SWB C10..SOLD 1977 SWB K10..my grandpa's.....never should have sold |
01-16-2015, 05:23 PM | #8 | |
Thanks for your replies guys, leaning more towards the ECE kit then
I have got to order loads of parts [LIST][*]Ididit column[*]Headers[*]Steering and front end rebuild parts (ball joints ect) [*]Rear brake drums / shoes etc [*]Seat belts [*]Suspension kit And some other small parts, i am finding it hard to find a vendor who can supply me all the parts so they can go in one shipment.
01-16-2015, 06:21 PM | #9 | |
What about Hotchkis? http://www.hotchkis.net/ |
01-16-2015, 06:48 PM | #10 | |
01-16-2015, 08:09 PM | #11 | ||
LS3 6 speed manual, full porterbuilt level 3 front and rear, big brakes etc. The issue is i don't have the time at the moment for it and just want to enjoy the truck for the next year or so, and here in the UK we have an inspection every year and it will not pass as it is at the moment due to wear in the shox/ joints etc so need to replace them and thought i would lower it at the same time. Just looked at hotchkis and it looks very high end stuff Quote:
01-29-2015, 06:17 PM | #12 |
Just thought i would update this.
Went for the ECE kit in the end with the front sway bar, along with a front end overhaul kit and a rear brake overhaul kit. Shipping still killed though Total was $2,800, $1,024 of that was shipping Via USPS. Just goto to wait for the parts now and have the pleasure of paying tax and import duty. Onwards and up wards
01-29-2015, 07:19 PM | #13 |
Paul, I would have helped you. Sorry that I am just seeing this.
Best Regards, Leon M. Instagram: @TheDirtyDianah
Bagged | 6.0L LS | T-56 (6-Speed Manual) | Turbo Burnout/Rolling Video: Chevy C10 Stepside 6.0L LSx & 6-Speed Manual |
01-29-2015, 08:06 PM | #14 |
I pieced together my kit to make sure I got everything I wanted/needed, I have a 3/5 drop. Shock relocators, bent trac bar, kyb gr2 shocks, 5 inch CPP springs, 3 inch cpp springs and that's all I needed. It was easier for me to save money and pile up parts overtime and install all once I got the last piece. Just my 2 cents
"Sometimes I do serve as a good bad example. Glad to be of service." My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809 |
01-29-2015, 08:09 PM | #15 |
Thanks for the offer, i looked into it and there was not much in it to be honest. By the time i had paid for shipping to someone in the US then arranged Either UPS or DHL etc to collect it and ship it to me in the UK it was around the same.
01-29-2015, 08:12 PM | #16 |
Glad that you are able to make it happen. Good stuff.
01-29-2015, 08:32 PM | #17 |
If someone could point me towards a online supplier for a Ididit column where i can configure the options that they list IE wash wipe option or headlight dimmer that would be good.
Summit and Jegs don't have it, and you can not buy direct from Ididit
01-29-2015, 11:45 PM | #18 |
Matts classic boweties sells those columns and is a forum supporter here. CHeck the vendors section. I use to live in England because my dad worked for the us government in the us schools on the bases. We had everything shipped in an APO address. Do you know anyone associated with airforce that could get shipments at an APO address and possibly save some?
01-30-2015, 02:27 AM | #19 |
RAT1968 '68 Cab/'71 Parts
I live near ECE, and am a continual "cheerleader" for their parts and service. Plus, not that what I do matters to anyone but me,
but I like to give what money I do spend to good people. Like a lot of Vendors on this forum, they are THAT. For sure. I'm willing to collect any parts from them and send them off to any Forum Member. But here's the problem with that...These guys are pros. They ship to everywhere in the U.S. and all over the world. That makes them pro shippers. And, they don't gouge on shipping. It's simply expensive these days...With a capital "E". So, if anyone wants some help from this end (Central California), whatever the task, I'm always glad to oblige.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
01-30-2015, 08:20 PM | #20 | ||
I have a RAF airforce base 2.2 miles away. The gym i use is right by there and some members from the RAF use it so will ask next time i see them. Quote:
Thanks for the offer of help, its nice to know people thousands of miles away who don't even know you are prepared to help.
01-30-2015, 09:30 PM | #21 | |
here that needed something over there.
01-31-2015, 03:25 AM | #22 |
Paul you have forgotten me i ship form the states on average every two weeks.
GMC K1500 1971 350 cu in th350 4wd Bondo Bob c 10 1971 stepside th 350 c10 1970 350 cu in manual air con stepside. |
02-21-2015, 09:37 PM | #23 |
Adrian what parts do you deal in then ? do you keep any stock or just get into order
01-07-2020, 01:51 PM | #24 |
This form is so awesome a person gets really good feedback in information from others still here I go again I'm ordering a drop kit from Speedway Motors for the front of my 67 C10 the kit does not offer add drop spring and they do not have upper and lower a arms my question is where should I look for a good a arm upper and lower with a spring kit from and I've seen others replace just the upper a arm with a tubular and not the bottom is that okay to do? I will try to post a picture with this reply as to why I want to replace the upper a arms as you can see in the picture there's an issue somewhere here.
01-07-2020, 04:48 PM | #25 |
