Old 01-15-2015, 09:04 PM   #1
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
GMC 305 4 barrel intake
Did GMC ever make a four barrel intake that would bolt on instead of the two barrel. I know a guy with a 65 Suburban that wants to convert it to two strombergs mounted on a four barrel intake.
Old 01-15-2015, 10:10 PM   #2
padresag
Re: GMC 305 4 barrel intake
no 4 brl manifolds. a common current upgrade is to put a 500 holley 2 barrel on them. inquire at the 6066 GMC site
ron
padresag is offline   Reply With Quote
Old 01-16-2015, 12:09 PM   #3
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
No 4 barrel intake...though I'm sure you could adapt a 4 barrel to the 2 barrel intake using trans-adapt. Kind of a waist though....but the biggest thing was a 500 cfm holley 2 barrel.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 01-16-2015, 02:57 PM   #4
MusicMan70
MusicMan70's Avatar
ERL on this site adapted a quadrajet to the two barrel intake. Another guy on the 6066GMC site did the same for an Edelbrock.
So you can probably open it up enough to adapt this Elco 2 two-barrel intake adapter for the demon carbs or whatever others he may have in mind.
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 01-16-2015, 03:41 PM   #5
padresag
http://6066gmcguy.com/holley.html is for the 500 holley setup. you may find by google how to modify the manifold for a 4 barrel as it has been done as above but the was another showing the steps. it was by a member of 6066 . if you post the question over there , I am sure that you will get a response
ron
Old 01-16-2015, 03:54 PM   #6
MusicMan70
MusicMan70's Avatar
http://67-72chevytrucks.com/vboard/s...=453161&page=3
MusicMan70
1961 GMC Suburban
Old 01-16-2015, 04:53 PM   #7
padresag
Originally Posted by MusicMan70 View Post
that is pretty identical to the other i was mentioning. more than likely where he got it from
ron
Old 01-16-2015, 05:45 PM   #8
aerotruk63
aerotruk63's Avatar
Thank You Ron for the suggestion and info. Thank you MusicMan for the info as well.
Old 01-16-2015, 08:12 PM   #9
duallyjams
duallyjams's Avatar
You would have to dig in the archives on 60-66 site to find the threads but pretty much like the pics already posted you can take the big 2 barrel intake and have it machined to accept a 4 barrel then add a throttle body for efi.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 01-16-2015, 09:29 PM   #10
aerotruk63
aerotruk63's Avatar
He wants to mount dual Stombergs. Asked me to start looking for an another intake so he can preserve the original. He'll modify another so the Stombergs are spread apart and higher up than the Speedway adapter.
Old 01-16-2015, 09:56 PM   #11
Corts60
Just here to tinker
Corts60's Avatar
http://6066gmcguy.com/DualCarbs.html
I performed this mod several years ago with the factory manifold….
Old 01-16-2015, 10:19 PM   #12
padresag
this guy built his own adaption
ron
