![]() Join Date: Dec 2013
brake booster
can i use a brake booster off a 79 on my 67 will the rod to the pedal line up???
Re: brake booster
Pretty sure it will not without modification.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
Re: brake booster
what we talking here like weld some holes up and drill new or a hole new mount ??
Re: brake booster
Do you have a booster mount for the truck now? If not, you either need to find one, or get a Captain Fab mount. The you would need to modify the rod on the booster to fit to the pedal.
Later mounts bolt right to the firewall, and I'm pretty sure all the square body trucks are like that. From the factory ours had a complicted mount with a linkage that puts the booster like 8 inches off the firewall.
Re: brake booster
ok thanks ill have to do some looking im just at work thanking
