Old 01-15-2015, 10:57 PM   #1
Super_Dave
Super_Dave's Avatar
1974 C20 Rear Axle Question
I have closed a deal on a pristine 1974 C20, 350, 2WD, M40 TH400, 14B 3.73 differential. I am collecting information for a future build. http://67-72chevytrucks.com/vboard/s...d.php?t=655783
I will be doing the ECE 2.5" C10 Drop Spindle kit. I also want to swap out the rear axles for a set of Dutchman axles that will be drilled for matching 5x5 C10 bolt pattern. This will retain the HD C20 parts but open up more wheel/tire combinations.
What I need to know, without disassembling things: Are the OEM C20 rear axles the C-Clip type of the Press On Bearing bolt in type?
Thanks!
--Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...d.php?t=655783
--Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...ghlight=Belair
"Life is tough - wear a cup!"
"Old Enough to Know Better - Too Young to Resist"
"Junk is something you will need three weeks after you throw it away."
Super_Dave is offline   Reply With Quote
