guess my mpg, please
69 gmc long bed half ton 2wd, 350 quadrajet gm aluminum dual plane, manifolds with true duals to the rear end, th400 idk rear end gear 32" tall tires, 3950lbs. going to make a 374mi one way trip and want to give my self a fuel cost estimate. my dad got 12ish, i think, from iowa to washington, same truck except 2bbl on cast manifold and 235/75-15 with a motorcycle, rear end, tranny in the bed and towing a small trailer with another motorcycle in it.
1962 olds cutlass http://classicoldsmobile.com/forums/...5-cutlass.html 1962 olds f85 wagon http://classicoldsmobile.com/forums/...-85-wagon.html 1969 gmc 1966 olds f85 |
Re: guess my mpg, please
Without knowing the rear gear, that it's well tuned, load, or the size of your right foot, I'll say 8 to 15 or 6 to 17 in the mountains. Estimate high and be happy. I always try to keep my expectations at the bare minimum. That way I'm always pleasantly surprised.
Jeff
I know a guy who's addicted to brake fluid. He says he can stop any time. 72 K10 396 75 Cj5 MPI 350 Chev 67 Chevelle 396, 4 speed 74 FXE 08 Tahoe |
im assuming its the standard ratio for a 69 half ton. id hope it'd be better then the 12 my dad got on the 2bbl with that load. i keep it as well tuned as i can and will likely give it a once over before i head out. ill be empty on the way out so the 3950lbs plus two people
10-11 if using E-10
Probably pretty close. Also depends on if you are going 55 or 70.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
I get about 8 mpg with a 350 with a Holley, headers, turbo 350 trans and 373 rear, I think I have a 28 inch tall tire, my engine is tired though and has low compression
1995 s10 blazer 4.3 1967 c10 350/350 fleet short 1993 s10 blazer 4.3l 4l60 RIP 6/20/14 2000 mercury sable Thats a how I roll |
![]() Join Date: Nov 2004
That's going to be quite a load to drag along... I'm going to go with 8-10. Towing my 18' boat with my modern Z71 with overdrive only got 12 mpg.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
![]() Join Date: Nov 2001
I would figure off of 10 mpg... but, the changing of fuel prices from station to station, state to state, etc... and knowing that stations on the hwy are more expensive than the stations in town, usually blows my estimates off track anyway.
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White 2002 Chevrolet 1500HD 4x4 Crew Cab 6.0L 4L80E Red |
i certainly hope you guys are wrong
![]() my dad getting 12 out of it with a 2 jet and that load gives me hope that without a load with a better carb, quadrajet, and taller tires( less rpms on freeway) i would get better mileage.
Have you noticed the size of those secondaries you will be using in that carburetor on all those hills? Plus... as stated above, you do not get as good of gas mileage with E-85 as with the good 'ole gas we used to have.
I wish you the best. I would budget for 10 mpg at $2.50 per gallon. So, figure $100.00 for fuel one way. You never know you might just be surprised.
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White 2002 Chevrolet 1500HD 4x4 Crew Cab 6.0L 4L80E Red Last edited by 67 cst swb; 01-17-2015 at 11:39 PM. |
Before I put the OD trans in mine I got 11 mpg all the time, towing a 20 boat or not, 350 with a q-jet.
1972 Cheyene C-10 "Ole Green" My Grandfathers truck (early 70's to 1983) My first vehicle (1983) Original 350 (3 rebuilds) 700R4 from Bowtie Overdrives ![]() |
I will be if you honest 10 will be pushing it....
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
#13 |
Damn what are you complaining about.. Gas in the Netherlands is at It's lowest in 6 years $4.50,- per gallon!
Feedback is always welcome! projects: 1969 Chevy C10 1950 GMC 100 1958 Chevy C60 Viking ratrod |
#14 |
And the Netherlands is the size of Maryland! You drive across the entire country with a single tank of gas.....
1970 C-10 LWB "Blu" Instagram (current build pictures) 70_nc_c10 |
#15 |
I have a 67 c10 with 350 375 hp 4bb and if i stay out of the secondaries i get around 14mpg
#16 | |
BlahBlahBlah
I googled square miles ... actually Netherlands is larger by approx. 750 sq. miles lol Both beautiful places to visit =)
… … … … … … … … ... … … … … … … … … … … … Last edited by CG; 01-17-2015 at 11:48 AM. |
#17 |
My 1969 C10 350/350 Will do about 15mpg running on propane (propane only costs $2,80/Gallon)
#18 |
gas is 1.85 for 87 where i live, going to fill up here and one tank should get me to my destination. im figuring 13mpg, will post what i actually get out of it after the trip, should be saturday.
#19 |
Yugh.. 87 isn't that like filling up with water? We can't even get below 93
Years ago in Florida I drove a '78 grand marquis which i filled up 87.. The engine knocking was so bad I drained the fuel en refueled with 93 or 95..not Sure anymore, decades ago.
#20 |
10 mpg. I didn't read any of the particulars, just made a guess that is safe for about any of these trucks.
Everything I own (except my Harley and diesel Jimmy) runs just fine on regular. I look at premium as a waste of money.
#21 |
I got 14 out of it, tried to stay at 55-60. Wish I had cruise control
#22 |
I always run 87 in it,
