![]() Join Date: Oct 2012
Checking door hinge
Re-installed doors using original door hinges with new pins. They are sturdy and work great except for in fully open position doors want to close.
Is there some adjustment or trick that would help doors stay in open position?
General Contrucktor |
Re: Checking door hinge
Friction plates on the hinges are there to prevent that.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
Sammy,
Can they be repaired or improved? Thanks.
http://67-72chevytrucks.com/vboard/s...oor+hinge+stop Hope this helps...
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
I haven't tackled this directly as almost everyone of mine could use new ones. Too many more important things at the moment. But when I do I will most likely fiddle with a spare set n replace them one at a time.
#6 | |
Thanks.
Would somebody be able to tell me how thick the stop pad is?
It appears to be about 1/8". Hoping for exact measurement. Thanks.
