Old 01-16-2015, 02:06 PM   #1
crazychevyc10
does this look like a 3in drop to you?
Do you guys think this looks like a 3in drop in the front to you guys? I just added a 3in drop spring and it doesnt look like it. I wish i would have measured it first. (the back is a 6 in drop with lowering blocks)
crazychevyc10 is offline   Reply With Quote
Old 01-16-2015, 02:11 PM   #2
67 cst swb
67 cst swb's Avatar
Re: does this look like a 3in drop to you?
Is there a motor in that truck? That will play a roll in how far it drops down.
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
67 cst swb is offline   Reply With Quote
Old 01-16-2015, 02:13 PM   #3
crazychevyc10
Yes it has a 350 in it. Granted they were old original springs but i really thought it would be a big difference in drop
Old 01-16-2015, 02:14 PM   #4
crazychevyc10
Just wondering if any of you guys went from original to 3drop springs and it looked like this.
Old 01-16-2015, 02:15 PM   #5
RenoKeene
Florida Edition
RenoKeene's Avatar
Cut one coil off your new springs, that should get you where you want to be.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 01-16-2015, 03:54 PM   #6
AirSpeed
AirSpeed's Avatar
That looks about right, I did the front of my 69 3", looks about the same. You have any before pics?
AirSpeed is offline   Reply With Quote
Old 01-16-2015, 05:00 PM   #7
CST10
CST10's Avatar
Looks like stock height. Did you compare the spring lenght to the old one when you took them out?
MyToys:
Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles.
Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop.
Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ.
Member of the Louisiana Classic Truck Club, LCTC
Member of the Louisiana C10 Club
Member of the Baton Rouge Drifters Car Club
CST10 is offline   Reply With Quote
Old 01-16-2015, 08:14 PM   #8
EARNHARDT#3
EARNHARDT#3's Avatar
I think once it's driven the front will come down.
EARNHARDT#3 is offline   Reply With Quote
Old 01-16-2015, 11:42 PM   #9
kitsbeach
kitsbeach's Avatar
Is the back 6" drop coil PLUS the block.?
Front doesn't look very low to me....3 plus a 2" spindle should take it down to the edge of the tire
Kitsbeach (Ken)
1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills"
1980 C20 Long to short & static drop "Square One"
kitsbeach is offline   Reply With Quote
Old 01-17-2015, 12:10 AM   #10
Possmguts
Possmguts's Avatar
If you just sat it down off the stands it will still be bound and will not sit where it will after its moved. You can try to turn the wheels back and forth a few times all the way and it may settle then if it dont run.
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline   Reply With Quote
Old 01-19-2015, 02:23 AM   #11
crazychevyc10
Its been on for 2 months now and i have driven it too and still no difference.
Old 01-19-2015, 02:25 AM   #12
crazychevyc10
Yes its a 4 in drop spring and a 2in lowering block in the rear. Im hoping with a 2"drop spindle in the front it will even out
Old 01-19-2015, 06:25 AM   #13
72freak
Rottenwood Garage Member
72freak's Avatar
this is what mine looked like after a 2.5-4 with 275-60-215 tires
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 01-19-2015, 02:44 PM   #14
Fitz
Absolutely right! It needs to be driven for the suspension to settle. When I posted my build thread all of the snarky little boys that can't build anything were saying , "That can't be a 3.5 in drop because the space above the tire is HUGE". Well, here's the before driving & after driving shots. It settled almost 2 inches! The only difference in the truck before and after was the installation of the interior and 500 miles on the clock! It will settle.
Fitz is offline   Reply With Quote
Old 01-19-2015, 03:29 PM   #15
67ChevyRedneck
67ChevyRedneck's Avatar
This happened to my 65 Mustang. There was in initial settlement when I drove it around a bit and all was great. After a few thousand miles it dropped almost another 1/2" and now my car sits too low and my car scrubs on hard turns with "speed". So now I have to go back and raise my car 1/2"
However, to the OP, sitting from my arm chair, your truck looks the same as my stock height truck. It should have at least dropped a couple inches immediately. Did you index the springs correctly?
My truck has no drop, just old original springs.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 01-21-2015, 10:48 AM   #16
ShawnAlexander
I did the 3" drop coils in the front and 4" in the rear. Mine set about where your is. Just need to put some miles on it. Did you have any steering tie rod clearance issues?
ShawnAlexander is offline   Reply With Quote
Old 01-22-2015, 04:27 PM   #17
4oldcars
4oldcars's Avatar
Needs drop spindles
4oldcars
Driving:
1971 Jimmy w/68 Chev front clip, 1953 Bel Air 2 dr hdtp, 1996 Roadmaster wagon, 2000 Eldorado
The ones I let go:
1931 2 dr sedan, 1935 pick up, 1938 2 dr sedan, 1962 SS 454, 1963 409 wagon, 1970 short bed, 1972 short bed, 1972 sub, 1976 short bed, 1986 long bed, 03 short bed
4oldcars is offline   Reply With Quote
