Need help with speedo gear after rear end gear change
Can somebody help me with changing the gear on the speedo cable at the Transmission after a rear end gear change. The truck as a 700r4 and I had a 3.07 rear end and this weekend I had it swapped to a 3.73posi and my speedometer is now about 10 miles an hour off.what is the best way to figure out what gear I need to change to on the transmission
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
Re: Need help with speedo gear after rear end gear change
Here is a link to TCI's page. They walk you through it pretty much, but you have to figure it out based on what you have and how you want to change it.
http://www.tciauto.com/tc/speedometer-gear-calculator/
I usually just add an external mounted ratio adapter of the percentage required, like these: http://www.partshp.com/speedometer_gears.htm
It "skips to the end", bypassing the math and any detail measurement errors regarding tire rolling radius and such. When I switched out the "Slim Jim" for a TH400 in my '63 Grand Prix the adapter I needed was already laying out on the workbench. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
![]() Join Date: Jul 2001
X2 on what Keith S. said with the gear ratio adapter. He guided me to the same website when I had a similar problem going from a sm465 granny 4spd to a TH350 auto. Had a 3:07 rear axle ratio in my '71 4x4 and I ordered an "off the rack" ratio adapter speeding up my speedometer. Easy install, 15 minutes while I drank a cold Bud. Speedometer is dead on exact using our Garmin GPS. HIGHLY recommend looking into the same fix.
Thanks again for your help, Keith. ![]()
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
Just throwing this out there as a quick fix. I have a portable garmin gps, it's got a speedo built in that runs off satellites. Costs around 100 bucks and there's no monthly fee. Might keep you from getting a ticket till you can get this figured out.
