Old 01-16-2015, 07:05 PM   #1
davepl
davepl's Avatar
2WD 3/4t 2-piece front friveshaft removal
My yoke is leaking through that little center button, so I need to pull the front driveshaft to get it out (I guess I could press the caps out in place, but I'd rather do that as bench work).
It's not immediately obvious how to get it out, and searching here yielded pretty much exclusively 4x4 results.
What comes out in what order? If I have to remove the carrier bearing housing do I drop the rear driveshaft first?
This is all just to get at something hidden by the u-joint, so I'm trying to avoid tearing the whole drivetrain apart...
The shop manual (which refers to it as a prop shaft) says that there may be u-bolts (nope) or you may have to "remove u-joints as described later in this chapter". So that's kind of useless.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 01-16-2015, 08:04 PM   #2
Mike C
Mike C's Avatar
Re: 2WD 3/4t 2-piece front friveshaft removal
Mark driveshaft where rear engages front so you can put back in same orientation.
Put oil drain under output of trans.
Remove rear driveshaft section. Unbolt carrier bearing. Pull carrier bearing assembly and front portion of driveshaft.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 01-17-2015, 10:15 AM   #3
harpo231
harpo231's Avatar
Yes ,,what he said ... drop backend of rear shaft from pinion flange and unbolt carrier it'll slide right out
harpo231 is offline   Reply With Quote
Old 01-17-2015, 04:21 PM   #4
davepl
davepl's Avatar
It's on a lift and I don't have one of those "tall on a stand" catch trays yet. I guess I could lower it, but:
- In the past I've stuck a different yoke in it the moment I pull the other one out, so you don't lose much. Sadly they only spare on I have is a TH400 that is larger than the 200/350/glide style.
Any other tricks to keeping the fluid in the trans (other than tipping the truck, which I can't do)?
Old 01-17-2015, 04:37 PM   #5
Custom/Ten
Custom/Ten's Avatar
I saw on Stacy David's gears he put a disposable glove over the end and then duck taped it on. Spilled about an ounce. Hmm, just hAd a thought, I would use an extra glove or two just in case, and some carb cleaner wherever you gonna put the tape so it doesent slide off.
Custom/Ten is offline   Reply With Quote
