Old 01-16-2015, 08:04 PM   #1
kevinr1970
Crew C30 vs C20 differences
I am under the understanding that all crew cabs share a "1-ton" frame.
I also understand that a C30 came with a full-float rear while a C20 came with a semi-float rear, but the semi-float is unique to the crew due to the spring perch and shock mount locations?
I am I on the right path here?
So what is different on the front?
Are the Crew C20 and C30 the same upper and lower control arms, or are the lowers different?
I was told that the only difference on the front of a SRW and a DRW was the rotor, but have never confirmed that.
I am going to convert my C30 Dually to single (and short bed eventually) and there is a guy parting a C20 crew.
I have Belltec 3" spindles on my crew now, so I can't just swap all the front end parts over.
Just wondering what all I could grab off this to help me convert to SRW.
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
