01-17-2015, 09:01 PM | #1 |
Rear engine mount bolt help!
I'm running a 350 with a 4 speed and the original rear bell housing mounts and crossmember. Does anyone know where I could source the bolts for the rear engine mounts? I've looked at regular grade 8 bolts but they don't look the same with the 'nose' on them. Would like to find the correct bolt since as you can see, I have a bent one....
thanks.
Once a Marine, always a Marine! My (Her) 57 Build "Beverly" My 66 Build "Betty" My 85 C10 "Old Blue" Help Me Find "Old Blue" OLD BLUE PART II |
01-17-2015, 09:58 PM | #2 |
Re: Rear engine mount bolt help!
put 2 or 3 nuts on it hold them in a vice and straighten it out
01-17-2015, 10:09 PM | #3 |
01-17-2015, 10:45 PM | #4 |
If you straighten it go to an engine shop and get it mag particle inspected.
01-17-2015, 11:48 PM | #5 |
IF you are worried about cracking it (I doubt it will) put it on the passenger side (less load)... I have straightened many of those never had a problem
01-18-2015, 01:49 AM | #6 |
60-66 Nut
The pointed tip is just to aid in alignment and starting the bolt in the threads. You could always take a new grade 8 bolt and give it a little point like that on a bench grinder. Just thread a nut on first and use that to chase the threads after you grind the tip.
01-18-2015, 08:51 PM | #7 |
A buddy out west is sending me a set for postage which is super cool of him. Looks like I'm tearing ol'betty down.
Check my build thread for updates!
