01-17-2015, 09:02 PM | #1 |
Active Member
WTB: '73-87 1/2 ton front axle 10 bolt backing plates
Looking for '73-87 1/2 ton front axle 10 bolt backing plates, one for each side. Thanks.
01-18-2015, 01:28 AM | #2 |
Re: WTB: '73-87 1/2 ton front axle 10 bolt backing plates
Might have a pair. Gimme til Monday.
72 GMC C2500 402/Th400 first truck (still have) 77 GMC C3500 CC dually Sold 70 C50 dump truck "Rusty" 87 K10 Suburban Sold 93 K2500 xcab 6.5TD 96 GMC K2500 Suburban 6.5 TD |
01-18-2015, 11:22 AM | #3 |
Active Member
Will do, thanks!
01-21-2015, 08:55 PM | #4 |
Early solid thick one piece plate or later abbreviated caliper bracket with tin shield?
83 K30 SRW 350 TH400 NP205 4.10 9' Fisher 85 K30 SRW 350 TH400 NP205 4.10 87 V3500 Dually 454 TBI SM465 NP205 4.10 9' Fisher 83 K2500 350 TH700R4 8600GVW Dual Tank 4.10 1973 Cheyenne Super 30 DRW Std Cab Z83 4.10 1976 Silverado C30 Std Cab 4.10 DRW (4 sale) |
01-21-2015, 11:09 PM | #5 |
Active Member
01-22-2015, 07:37 AM | #6 |
The interchangeability may not span as far as 73-91. Certainly for a period of at least the late 70's-91, the axles otherwise have the same knuckle and spindle and thus, can use either style. I may have a later tin style shield, for one side. Useable and not rusted through, but I'm in the salt belt too.
01-22-2015, 10:39 PM | #7 | |
Active Member
I got the axle from the local salvage yard; they set it on the ground and twisted up the shields. I did find a thick one and plan to use it if I can. The axle ring gear is stamped 10 85 (1986 model year?) and I am still trying to figure out the axle stamping code to determine the year of the unit. Seems to be an extra character based in the code based on the information I found. Thanks again for your help! |
01-23-2015, 07:17 AM | #8 |
Ring gear stamped 10 85 is October 1985 for 1986 production. I'll dig out the caliper bracket/shield I have and image. There are lefts and rights.
01-23-2015, 06:49 PM | #9 |
Active Member
01-24-2015, 09:02 AM | #10 |
I have three caliper bracket/rotor shields. Caliper mounts are good. Shields have rust through holes from road salt. They're available if you're in a pinch but I'm sure that there are cleaner out there.
01-24-2015, 10:17 AM | #11 |
Active Member
I will pass on the rusted-through shields GonicGM but thanks. The information you shared was great though, it has helped.
02-02-2015, 08:36 PM | #12 |
Active Member
Bump.
04-01-2015, 06:45 PM | #13 |
Active Member
ttt
04-01-2015, 08:09 PM | #14 |
Miechiels auto in Howell had a couple late 80's K5's there last time I was there. May want to check there.
04-01-2015, 08:27 PM | #15 |
Active Member
04-01-2015, 08:40 PM | #16 |
Are you asking if they'll do it for you, or if they will be ok with you taking them from an axle assembly? For question one, bring your tools....it's a you pull type place. For question two, they don't care what you take and seem to not care how you remove it as long as you stop and pay on the way out.
04-01-2015, 09:52 PM | #17 |
Active Member
Awesome, I will be shopping this weekend!
04-03-2015, 04:41 PM | #18 |
Active Member
Finally took my rotors off today, found I have the same setup as one selling on EBay so I bought those.
This link was helpful! http://67-72chevytrucks.com/vboard/s...=536415&page=2 BTW, the local yard had the older full cast backing plate on a removed front axle in case anyone is looking for one or two. My existing tin shields are rusted through; maybe powder coat the new ones? |
04-04-2015, 10:53 AM | #19 |
Did you go to the yard in Brighton or Howell? Havent had time to check out any of them. Im trying to rebuild 2 trucks with the help of a donor surburban, but im always looking for 73-87 truck parts.
04-04-2015, 12:04 PM | #20 |
Active Member
There are two yards in Howell I went to, Regal and Miechiels. They both have at least three square-body trucks. Both have u-pick and Regal has a "they-pulled" office too.
