![]() Join Date: Feb 2012
67 with leaf spring
I'm looking at a 67 Shortbed that the owner says was converted to rear leaf spring??? Has anyone ever heard of this and what should I look for when I check it out this week. Thanks. Lou
Re: 67 with leaf spring
Most Chevy's were coil and most GMC leaf, but the other setup was optional on both.
My '69 short step is a factory leaf truck and there are plenty more out there. Hopefully it's a factory leaf truck and not somebody's home job...
Mike C beat me too it.
I haven't personally seen any trucks that were converted from coils to leafs but anything is possible. Since rear leaf springs were a factory option for Chevy's, my guess would be that the truck originally came with the leafs and he thinks it must have been converted since some people think that all 2wd's came with rear coils/trailing arms. Does he known for sure it was converted?
FOUNDING MEMBER OF THE DRUM BRAKE CLUB Second Owner 70 C-10 Second Owner 93 GMC C1500 Third Owner 99 C2500 Crew Cab Short Bed |
![]() Join Date: Sep 2007
Look to see if shackle mounts are bolted on or rivited. Bolt on means its been converted most likely
1967custom |
I'm going to look at it this week I'll let you guys know. Spid is gone and cab was totLly redone and stripped which worrys me a little since there are no pedal, heater,etc.
