01-17-2015, 10:48 PM | #1 |
What is this brake part?
I was working on the rear drum brakes today and discovered this spring is broken. I can't find it online or in my parts books. Anybody know the name or part number for it? It is on a 1971 Chevy C-10.
01-17-2015, 10:56 PM | #2 |
Re: What is this brake part?
That sucker keeps the spreader from rattling around. You should be able to get s set at the parts store
http://smg.photobucket.com/albums/v655/aaronhero/ |
01-17-2015, 10:57 PM | #3 |
01-17-2015, 11:06 PM | #4 |
Thanks for the responses! This forum is great!
So if it just keeps things from rattling around, then one loop broken off is not a big deal as the spring does not compress or have a load on it. Am I correct in my logic or should I go get a new part? |
01-17-2015, 11:14 PM | #5 |
Rear brakes are overrated...lol
-Keegan- '72 Jimmy 4x4 - 5.3/4L65E/NP205 swap http://67-72chevytrucks.com/vboard/s...d.php?t=663780 |
01-17-2015, 11:34 PM | #6 |
Until another chunck breaks off and jambs something up. You can get a set with new springs, the little pins and nuts and other parts for $10/15. Brakes are important.
01-18-2015, 12:21 AM | #7 |
I agree. If the springs are so old that a coil broke off, then 12.00 bucks at NAPA and a couple hours of your time is well worth it
1967custom |
01-18-2015, 02:27 AM | #8 |
01-18-2015, 10:57 AM | #9 |
Replace it. But it doesn't come with the rear brake hardware kit. At least it didn't come with mine when I got it last week from O'reilly.
