Old 01-17-2015, 10:56 PM   #1
71Dreamer454
71Dreamer454's Avatar
Hoping to start my project need some advice
I have a Chevy 454 crate motor and a turbo 400 Trans that I plan on having dropped in a 1971 c10. I have most of my ideas thought out as to what I want appearance and function wise with one exception. I want to run 17" American Racing Tourque Thrust wheels. I will drive this truck often but not daily. I don't want it lowered down to the frame but want a lowered ride height that is functional. Should I go Air Ride? If not what size drop do you all recommend?
Other question is custom head unit. As I would like a modern touch screen head unit are there kits for these? Should I just mount it below the dash in some sort of custom mount. I plan on putting in a bench seat with some houndstooth trim to keep a classic look so I don't want to run a console up the middle as it won't have buckets.
Thanks for the advice and for the add to this great forum
71Dreamer454 is offline   Reply With Quote
Old 01-18-2015, 10:24 AM   #2
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Re: Hoping to start my project need some advice
Sounds like a perfect ride. I think Early Classic Enterprises 4-6 drop would be perfect with that setup. http://www.earlyclassic.com/catalog....ry=Drop%20Kits
Tom Vogel is offline   Reply With Quote
Old 01-18-2015, 10:58 AM   #3
Mike C
Mike C's Avatar
Are you planning on towing/hauling at all?
If yes, I'd do 3 1/2" / 5" ECE kit.
If not, 4 1/2" / 6" kit. Keep the 1" block in your back pocket if you want to go a little lower.
Here is my leaf spring truck. 4 1/2" drop with ECE disc conversion spindles and 2" springs. Rear is a DJM flip that lowered back 7". Wheels are 17x8 (4 1/2" bs)and 17x9 (5" bs) Summit Legends. 235 55 17 and 275 55 17.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 01-18-2015, 05:47 PM   #4
71Dreamer454
Nice. I like the stance a lot. No towing or serious hauling I have the work truck for that.
1971 Chevy C10 (Project Truck)
1991 Chevy 454 SS
2010 2500 HD 4x4 Duramax
Show Class and Haul Ass - Wear a Bow Tie!
