Old 01-18-2015, 01:38 PM   #1
Gregski
Gregski's Avatar
What's that loud thud behind driver in lower corner of cab.
seems like any time I go over some speed bumps a bit faster than I should I hear a loud thud behind me, behind my left elbow, sounds like somebody left a large hammer behind the bench seat (yes I checked, there is no hammer behind the bench seat, lol)
my truck bed is empty, cab is clean, I wiggle the driver side door and don't hear anything loose in there, it sort of seems like it may be under the cab right behind the cab, I honestly don't know I looked under the truck nothing seems lose
any ideas fellers?
1974 GMC 1500 350 manual 2WD
Gregski is offline   Reply With Quote
Old 01-18-2015, 01:44 PM   #2
J Knight
J Knight's Avatar
Re: What's that loud thud behind driver in lower corner of cab.
Fuel tank hitting the bottom of the cab maybe due to a broken or rotted strap.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 01-18-2015, 01:52 PM   #3
Gregski
Gregski's Avatar
Oh, should have mentioned, only have one fuel tank on the opposite side ie the passenger side, good point though, so don't think that's it
Old 01-18-2015, 02:43 PM   #4
homemade87
May be the cab body mounts. Those things will make noise if they are wore out. The frame and body will move around a lot. Mine were like power when I replaced them.
homemade87 is offline   Reply With Quote
Old 01-18-2015, 04:56 PM   #5
donut
donut's Avatar
x2, mine would clunk bad until replaced.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 01-18-2015, 07:40 PM   #6
tucsonjwt
My guess is loose exhaust/exhaust hanger.
tucsonjwt is offline   Reply With Quote
Old 01-18-2015, 08:37 PM   #7
Robert Crandall
Mine does it, and I found the problem to be as described in posts #4 and #5. It is on the list to be fixed.
Robert Crandall is offline   Reply With Quote
Old 01-19-2015, 01:59 AM   #8
86c20
86c20's Avatar
i got something like that found it was some little tool in the cab corner something to check. but my money would be cab mounts.
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph
1985 k30 "the ice cream truck from hell" no rust az truck
197-8??? c30 "ramp truck" 454
1978 monte carlo 350 350th with 2.73 gears. no rust. sc car
86c20 is offline   Reply With Quote
Old 01-19-2015, 08:18 AM   #9
homemade87
If your cab and core support mounts have never been replaced I would suggest replacing them even if this is not the source of your noise. My cab had a miss alignment to the bed. Thought the frame was out of wack . It was the body mounts . It also rides so much better and everything lines up now.
Old 01-19-2015, 12:38 PM   #10
Rich84
Rich84's Avatar
Check the condition of the rear leafs also..Mine were broken at the eye. It wasn't really noticeable until I unbolted them and they fell out..LOL
Rich84 is offline   Reply With Quote
Old 01-19-2015, 03:15 PM   #11
Super_Dave
Super_Dave's Avatar
I have the exact same sound in my '74 C20 when I go around right hand corners. Thought it was behind the seat too but my cab is empty. Got to thinking it might be cab mounts, loose exhaust hanger, something... but it's only when I turn to the right.
Guess I have an under body experience coming up...
--Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...d.php?t=655783
--Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...ghlight=Belair
"Life is tough - wear a cup!"
"Old Enough to Know Better - Too Young to Resist"
"Junk is something you will need three weeks after you throw it away."
Super_Dave is offline   Reply With Quote
Old 01-19-2015, 07:28 PM   #12
midnight rambler
midnight rambler's Avatar
in mine it was a beer bottle
midnight rambler is offline   Reply With Quote
Old 01-19-2015, 11:21 PM   #13
motornut
78K & 79C Jimmys
motornut's Avatar
Shock mount?
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 02-02-2015, 10:05 PM   #14
Gregski
Gregski's Avatar
not in the location I expected since I found this Sea horse looking pin in front of the driver side door by the top hinge, instead of the back of the door, but we may have our first suspect, it's a pretty heavy piece of metal so maybe this was the thud, I will drive around a bit and report back to you all
Old 02-02-2015, 10:36 PM   #15
greg64
greg64's Avatar
Greg, the seahorse is a broken piece of the spring that's part of the door hinge assembly. My body mounts were shot too, in fact the body was sitting on the chassis.
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
Old 02-04-2015, 02:28 AM   #16
Your41Plague12
Your41Plague12's Avatar
Mine did the same thing and it was the body mounts and braces. They were rusted out badly, and by the time I swapped cabs, the only thing holding my cab to my frame was my steering and shift linkage.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 02-08-2015, 12:00 PM   #17
Gregski
Gregski's Avatar
Donkey Kong, I guess it wasn't the sea horse (door hinge spring) as the sound is still there, seems like the offending piece slides forward when I brake and slides back when I accelerate
Old 02-08-2015, 01:35 PM   #18
tucsonjwt
My 76 had some kind of weight connected to the shoulder harness (I think) which would make that noise. I don't hear that on my 83. Maybe Keith can explain how that works.
Old 02-08-2015, 11:40 PM   #19
Gregski
Gregski's Avatar
interesting but I only have the lap belts in this '74
