Old 01-18-2015, 07:11 PM   #1
ratrodsrule1
Flywheel
I'm swapping a 250 six cyl. With a Three speed manual transmission to a 350 v8 and still keep the three on the tree. Will my existing 250 flywheel fit the 350 ? If not what flywheel do I need to search for?
We make too many wrong mistakes..................Yogi Berra
ratrodsrule1 is offline   Reply With Quote
Old 01-18-2015, 10:53 PM   #2
JJR
JJR's Avatar
Re: Flywheel
Yes, your current flywheel will work on the 350. Did your truck have the HD Clutch option? If not, it came with a 10.5in clutch instead of the 11in HD (and standard with a small block) Clutch. If you tend to tow or load the bed down, you might want to get another flywheel that you can run an 11in/12in clutch kits.
FOUNDING MEMBER OF THE DRUM BRAKE CLUB
Second Owner 70 C-10
Second Owner 93 GMC C1500
Third Owner 99 C2500 Crew Cab Short Bed
JJR is offline   Reply With Quote
