Old 01-18-2015, 07:58 PM   #1
Dan87GT
New Ignition Switch...Starts then stops....
Hello.....I replaced an aftermarket ignition switch in my 57 today with an original replacement....after installing my truck starts then immediately shuts off....I can hear the electric fuel pump fire up when I turn to the "start" position...any thoughts?.....maybe I do not have it connected correctly....
- Picture from the back on the dash
- Red wire is power
- Purple is the solenoid
- Pink is the ignition coil
- Orange are the accessories
- Painless wiring harness...
thank you!.....yes...I look like a crazy man in the picture!...
Dan87GT is offline   Reply With Quote
Old 01-18-2015, 08:29 PM   #2
Northern lights
Re: New Ignition Switch...Starts then stops....
Sounds like you don't have power to the "run" position only the "start" position so it starts then shuts off when the key goes back to the run position.
Northern lights is offline   Reply With Quote
Old 01-18-2015, 08:29 PM   #3
OrrieG
OrrieG's Avatar
Are you running an HEI distributor, if not you are missing a wire. Green goes directly to the coil during starting, the #1 ingition terminal should have a wire that goes to the resistor then from the resistior to the coil to reduce voltage during normal running to keep from burning the points. If you are running an HEI you need to have a 12v ignition on only dedicated wire to the HEI so you get full voltage only when the engine is running.
Here is a diagram I found, you are missing #1 ignition.
OrrieG is offline   Reply With Quote
Old 01-18-2015, 08:43 PM   #4
Dan87GT
Sorry....yes, I am running an HEI....so do I run a jumper from the battery term to the ignition #1 terminal?....
Below is a picture of the aftermarket switch I removed...and the 4 wires...center is purple solenoid wire..
thanks again!...
Old 01-18-2015, 10:17 PM   #5
Dan87GT
Ok...moved the Pink coil wire to the "Ign #1" spot....she barely started...and was hard to start after ..but it did run....I found this on the interweb....
Jumper "ign #1# & "ign #2"??
thank you!!....
Old 01-19-2015, 12:10 AM   #6
dyno
dyno's Avatar
Unplug the connector at the HEI, get a tester and see if you have 12V with the key in the "run" position. I had issues when I first fired my new motor last week after a complete re-wire. My problem was that I didn't have 12V to the HEI when the engine was cranking, but if I released the key to the "start" position, it would fire.
"Built- not bought"
1958 GMC 150 4x4 in progress
1980 K20- Restored
1985 K3500 Flatbed
58 GMC 4x4 build thread:
http://http://67-72chevytrucks.com/vboard/showthread.php?t=557675
dyno is offline   Reply With Quote
Old 01-19-2015, 09:57 AM   #7
Dan87GT
Added a jumper between "Ign #1" and "Ign #2"....starts/runs like a champ!...
thanks for the input....
Old 01-19-2015, 04:14 PM   #8
OrrieG
OrrieG's Avatar
Yea! put a meter on the HEI lead at the dist to make sure you are getting full 12V, that seems to be an issue with them and going thru the switch "might" cause a drop.
