Old 01-18-2015, 08:24 PM   #1
53lowdown
Junior Member
53lowdown's Avatar
LMC Fuel tank sending unit
I have a 20 gal LMC fuel tank that mounts behind the rear axle. I think the sending unit is bad. Guage always reads empty, but disconnect the wire at the sending unit and gauge goes to full.
Question is, is there some other readily available sending unit that fits these tanks? I've heard it is a 'blazer' style tank. Just wondering if I can get a replacement sender at local parts store instead of ordering another one from LMC.
_______________________________________
62 SWB BBW (under construction)
86 Vette Convertible
53lowdown is offline   Reply With Quote
Old 01-18-2015, 10:20 PM   #2
Chevy Fleetside
Chevy Fleetside's Avatar
Re: LMC Fuel tank sending unit
Do you have the 0-90 ohm or 0-30 ohm sender. I had the problem with my kit. It is the same but not bought from LMC and when I took the sender back out some how the weld to the power wire broke. I could not get it to weld back on so I just drilled it out and used a brass bolt. It is not really a wire but it is a metal band. Take out the sender and make sure that is still attached.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 01-19-2015, 12:48 PM   #3
Chevy Fleetside
I found a few pictures of the sender.
Old 01-19-2015, 11:41 PM   #4
53lowdown
Junior Member
53lowdown's Avatar
Thank you - will give that a try
