Old 01-19-2015, 12:38 PM   #1
Hotrod1952
Back-up Light Idea
Low Buck LED Back- Lights:
Got an idea the other day on my back-up lights on my 66. I wanted to make them LED. Started pricing and almost fell out of my chair. Over $100. So I ordered up some 2” trailer Led’s With the rubber mounting and went to my work and made up two of the bushings(see hand drawn PDF print). I plan to make a 2.950 hole where the light mounts and weld the bushing into place. I suppose you could drill 2 holes and countersink the heads just as well. All together I had about $30 in the two Led’s.
Hotrod1952 is offline   Reply With Quote
Old 01-19-2015, 02:40 PM   #2
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Re: Back-up Light Idea
great job. any info on the LED lights? model number?
Sick5 is offline   Reply With Quote
Old 01-19-2015, 03:24 PM   #3
Hotrod1952
These are the ones I bought.
http://www.ebay.com/itm/LOT-2-of-CLE...item58bbb021e4
Looks like I paid plenty for them. I think I figured out what they are
Brand: Recreation Nation.
Model: 102009c
Available here for less:
https://recreationnation.me/main/con...as-9-led-bulbs
Old 01-19-2015, 05:40 PM   #4
markeb01
Senior Enthusiast
markeb01's Avatar
Great idea and nice execution. Should make backing up at night a lot easier. Thanks for sharing!
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 01-19-2015, 06:12 PM   #5
Mathew21
Mathew21's Avatar
Nice job!
It only has original paint once
Mathew21 is offline   Reply With Quote
Old 01-19-2015, 06:20 PM   #6
earl84
Very cool. I'd like to see this completed. I think for tail lights LED's need some kind of resistor or something, do these need that as well. I'm no electrical guru, by any means.
earl84 is offline   Reply With Quote
Old 01-19-2015, 09:12 PM   #7
Hotrod1952
Red face Re: Back-up Light Idea
I tested them across my truck battery and they lit right up. I think blinkers/tail lights require either a load resistor or a no-load flasher. I'm working on the install tonight.
Old 01-19-2015, 09:47 PM   #8
Hotrod1952
The photos.
Old 01-19-2015, 11:27 PM   #9
64shortbox
64shortbox's Avatar
Thanks for the share & the information. Since my 64 didn't come with back up lights I can knock out my holes to fit the LED set up. A BIG Thank You for your information!
64shortbox is offline   Reply With Quote
Old 01-20-2015, 12:53 AM   #10
1966FLEETSIDE
1966FLEETSIDE's Avatar
Are you gonna go with l.e.d tail lights also ?I've seen their a pretty penny as well.
1966FLEETSIDE is offline   Reply With Quote
Old 01-20-2015, 09:53 AM   #11
Hotrod1952
Yes I am. I bought those last June at the Back to the Fifties show in Minneapolis.
Old 01-20-2015, 01:31 PM   #12
newbe351
Anyone know how much of a resistor? Do you just install it in-line? I paid a pretty penny for one of those loud flasher units (my blinkers don't self-cancel and I don't like driving around with my blinkers on). I would like to switch out to LED tail lights, but don't want to lose the flasher unit.
newbe351 is offline   Reply With Quote
Old 01-21-2015, 10:06 PM   #13
chris1044
The issue is that with LED there's basically no load on the circuit - hence the stock flasher does not work. You need to source resistors that result in a similar current draw to the original filament bulb.
They do make custom LED light flashers, but I'm not sure there's anything for our trucks and it is likely much cheaper to just wire resistors in series (NOT parallel!). That means in-line. Really doesn't matter if it's up stream or down stream of the LED.
I don't know enough about the circuits and how they're run to make the call on the resistors. My guess is something fairly low, but they're going to need to be fairly large to handle a decent amount of wattage to get the flasher to work - meaning not the tiny resistors you buy at Radio Shack or the wafer style units you see on PCB's. DigiKey is a great source for this kind of stuff...can probably find the right ones on there for less than 5 bucks each.
chris1044 is offline   Reply With Quote
Old 01-21-2015, 10:44 PM   #14
53Sparky
53Sparky's Avatar
Here's where I got the resistor for my daughter's S-10. Should work perfectly for your application too.
https://www.superbrightleds.com/more...ion/2178/5078/
We'll burn that bridge when we get there
My current project: Rust Therapy 62 C10
Numbers 6:24-26
53Sparky is offline   Reply With Quote
Old 01-22-2015, 01:06 PM   #15
newbe351
This should be the ticket for my use.
https://www.superbrightleds.com/more...r-kit/190/831/
Thanks for the heads up.....
